Question about Epson Artisan 800 All-In-One InkJet Printer
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using ADF. HELP!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Posted on Jun 07, 2012
  • Vincent Brunelle Jul 20, 2012
    were did you find the directions to disasemble and replace the part?/
  • nicola_tosia
    nicola_tosia Oct 09, 2012
    hi, were did you find the directions to disasemble and replace the part? I have exactly the same problem. Thx in advance
    Welcome Back:
  • 3 Answers
Here are the two steps I used myself to solve this:
1. Complete your online registration with Epson
2. Call Epson tech support about the ADF jams. You may have to spend an hour going through various troubleshooting steps with them.
They simply sent me a replacement printer. This is cheaper for Epson than trying to actually fix the problem!
Posted on Nov 02, 2010
  • EpsonOK Nov 20, 2010
    I've just had an even faster experience. As soon as I described the ADF malfunction, they said "we'll FedEx a replacement and pay the shipping both ways." (I did have to make a deposit until the old one gets back to them.)
  • kjw2001 Jul 18, 2011
    I did the same thing and they replaced it with a well worn unit! Garbage!
A problem with epson artisan 810
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 08, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Paper jam sign on top of ADF,even when there is no paper jam
Jul 31, 2013 | Toshiba E - Studio 810 Multifunction...
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Epson Artisan 800 ADF jams ever time. THere is no paper in it and I've unplugged it and restarted it multiple time. Havn't had it that long. 1 year or maybe a bit more.
There are two gears that are made of plastic that have hard rubber toothed sprockets pressed on them. These sprockets split and allow the drive motor to slip. Epson will only sell the motor assembly and not just the gear. I used a dot of supperglue to repair the sprockets and all works fine now.
Sep 04, 2010 | Epson Artisan 800 All-In-One InkJet...
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 All-In-One InkJet Printer Logo
6,935 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
