Question about Behringer EUROPOWER EP2500 Amplifier
I have a Behringer Europower PMH8805 mixer. I need the code of the microchips, cause mine are messed up.
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Posted on Jun 25, 2010
caroldon
  • 17129 Answers
SOURCE: my behringer europower EP2500 poweramp has a bad
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
  • 5603 Answers
SOURCE: My Behringer Europower Pmp5000 Powered Mixer blew
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
Posted on Nov 27, 2010
  • 5603 Answers
SOURCE: behringer europower pmp1000, mixer unit,
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Posted on Jun 26, 2011
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Need part # for the Program Push Button Control for the effects on a PMX2000 power mixer
You will have to call Behringer in Woodinville WA to get the Behringer part number. Their phone is:
(425) 939-3200
With the number plus an incident number that Behringer will give you, you then call FullCompass who is the parts distributor... Then, unless they have it in stock, plan to wait a long time to get the part. FullCompass phone:
800-356-5844
Lots of luck... I have waited for three months for parts.
Apr 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Jun 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
504 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
