Question about Coleman 2 Burner Compact Gas 425F499G Grill
Why my turkey fryer won't stay lit - Coleman 2 Burner Compact Gas 425F499G Grill
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2011 | Imperial IFS40 Deep Fryer
We used the master built turkey fryer just once after we took turkey out it will not turn back on
That is usually a problem with placing the heating unit into the bracket correctly. If is isn't put in properly the unit won't even power on. You may need to take it off and on several times to get it right.
Jan 02, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Cannot get burner to stay lit-gas going thru it but when red button released it goes out
I bought my fryer in November 2010 worked good for that Thanksgiving. Went to use it this year and thermocuople kept shutting off I used a brick to kep red button pressed in.
After turkey day I removed my thermocouple and installed a direct conection. I used a McMaster-Carr p/n 93590A220; Metric 18-8 Stainless Steel Coupling Nut M8 Screw Sz, 1.25mm Pitch, 38mm Length, 16mm Width, $7.95. I'm not sure about the exact thread size the Brinkman hose end and brass fitting on burner uses. However, I found 8mm threads to be the closet. Use thread sealant and it works great!
I tried 1/16" pipe fitting bit it is not correct.12_5_2011_6_08_54_pm.jpg
Nov 25, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Cant get the flame to stay lit after holding the red button
THIS IS FROM BRIKMANN WEBSITE SUPPORTMake sure the tip of the thermocouple is located over the edge of the burner so that it gets hot when the burner is in operation. Also, check all the wiring connections to make sure nothing has come loose. It is also important to use the turkey fryer with the pot that comes with the unit. The pot must sit on the spring loaded temperature switch in order to determine the temperature of the liquid in the pot.
Jun 23, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Coleman 2 Burner Compact Gas 425F499G Grill Logo
545 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Treefrog15
Treefrog15
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
