Question about Nikon FM10 35mm SLR Camera
I have a nikon fm10..when changed my lens to 50mm f1:1.8D, i would press the shutter release button, then the shutter will close,just close! i know it suppose to close and open rapidly, (my shutter speed is 1/125) and it just stayed closed until you wound the lever and press the shutter release again. please help!
    Brigadier General:
  • 3,006 Answers
Does this fault happen only with that lens? Also, you're wrong about the shutter: it appears you're mistaking the shutter assembly for the lens diaphragm (also known as the "iris").
Older lenses often have sticky diaphragms, usually due to oil migrating onto the individual blades and sticking them together. A sticking diaphragm can interfere with the shutter operation on some SLR's.
Fixing a sticky iris is usually a professional job, but if you're careful then with a simple non-autofocus lens like yours it's often possible to do on a DIY basis but will be very fiddly. The object is to get to the iris blades and to then thoroughly clean them. They're Teflon coated so should slide over each other without lubrication, but their pivots normally need the tiniest bit of lubrication. If you try and fail then you've lost nothing as the lens was effectively scrap anyway and there are plenty of cheap/free replacements around.
Posted on Sep 10, 2010
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
How to use remote shutter release HRN280
First, you need an adapter to fit the HRN280 to the D90. You can order this adapter by emailing sales@hahnel.ie .
Using the adapter, connect the release to the jack in the side of the D90. After that, simply use the button on the release the same way you use the shutter release button on the camera. Press it halfway to focus and meter, press it all the way to take a picture. In addition, the remote has a slide lock so you can take continuous pictures or use the bulb setting.
Jul 11, 2012 | Nikon D90 Digital Camera with 50mm lens
Re. Contax 167MT problem -- When the depth of field button is pressed the lens does not close down to the set aperture. Also when the shutter release button is pressed the lens does not close down. My two...
The 80s 167MT uses good old fashioned mechanical links between the camera body and lens. Remove the lens, and press the depth of field button. If you don't see the lever that connects the aperture control from in the camera body to the lens move, then something's obviouly broken in the camera body.
Nov 11, 2017 | Contax 167 MT 35mm SLR Camera
HELP APERTURE PROBLEM! When I attach any lens to the Nikon FM10
This is normal. the lens stay at the largest opening so you can see to focus, then the mechanics will close to the setting when the exposure is made. This is part of the reflex in single lens reflex (SLR). This part staying open when you focus keeps lyou from having to open the aperture to focus and then close it to the correct setting to shoot the picture.
Jan 29, 2010 | Nikon FM10 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Nikon FM10 shutter wont deploy with lens on.
Check the lens. Does the diaphragm move freely when you move the f/stops? Put the lens on f/8 or f/16 and push the pin in, it should move freely and close to the f/stop you set. If not the blades may have oil on them. Also if it is free then set the lens to the smallest aperture and if there is a button push it in to lock for auto aperture set.
Dec 06, 2008 | Nikon FM10 35mm SLR Camera
I have two different lens one is stronger than the other.Sometimes I take the perfect picture then other times not so good.How do I know which lens to use for close up or i want a distant shot at a cl
Do you mean that, you press the shutter release once and the shutter stays open until you press the shutter release a second time. If so, check your shutter speed setting. If it is set to "T" (Timed Exposure) the camera is working correctly. Change your shutter speed to an appropriate setting, such as 1/125. If that does not solve the problem, you might need to take it in for repair.
Nov 10, 2008 | Nikon F65 35mm SLR Camera
Nikon FM10 35mm SLR Camera Logo
210 people viewed this question
Top Nikon Photography Experts
Bart Pulverman
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
