Question about Westinghouse Electric L1916HW 19" Monitor
Unable to get a picture on the monitor even though it is on
  • 11,361 Answers
Http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20L1916HW/
Check the caps in the power supply/inverter board for leaking/bulging tops and bottom seals, if you have white screen , then it may have blown fuse on the T-CON board.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 10, 2010
When I turn my PC on you can hear it come on but the screen is black.
It sounds like you might have a problem with your video card. If you turn it on and see nothing, not even the gateway logo, than you either have a video card issue or a monitor issue. Hook up the mahine to another monitor to test.
Jan 04, 2011 | Gateway Computers & Internet
Monitor does awake from sleep mode
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
I cannot adjust anymore the parameters of the monitor from the 4 keys from the front panel and my brightness is extremely low. What can be done? Regards, DP consens.consulting@gmail.com
Unfortunately it sounds like the crt or picture tube is failing. Even though some can be rejuvenated it will be costly getting crt replaced or rejuvenated.
Jan 03, 2010 | CTX PR705F 17 in.CRT Conventional Monitor
Hi, I was using my HP Pavilion notebook with Vista when it froze. The cursor wouldn't move and I was unable to do anything. I tried contol/alt/delete to shut it down, but that didn't work. I then held the...
you could have accidently changed to external monitor with Fn +F(the number is 8 on my comp but could be 5 on yours-check keys on top of the keyboard it has a picture rectangle / little TV), anyways to check that attach external monitor to your laptop(must have a VGA cable) if you have a picture on external monitor try Fn + F(depends on what you have on ur keyboard) it should bring you a window with choices to choose laptop LCD or external LCD choose 1st one .
hope that is it.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
When I try to attach a photo from my "my pictures file" I click browse, and my file opens, but I am unable to scroll through it. It freezes. Occasionally it will scroll, but will freeze when I try to...
Even though you want to attach a picture, instead of attaching a photo, try attaching a file instead. You can then select the photo. I think it is some sort of quirk in Yahoo. I had the same problem.
Nov 11, 2009 | Yahoo Mail
Fee flashes even though apeture ring is set to
I have the same prolem. I think it has soming to do with the Meter coupling lever , it protrudes top of the Nlkon F-mount on the front of your camera. it may be need of repair
Sep 12, 2009 | Fuji FinePix S1 Pro Digital Camera
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
Unable to load more than ~50MB into df780 digital picture frame
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
Jan 07, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Problem with macally icecam
1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
A new Save window will pop up, set up the filename and location and click SAVE button.
Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
Dec 25, 2007 | Macally IceCam Personal Web Camera
Westinghouse Electric L1916HW 19" Monitor Logo
176 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
pankaj rautela
pankaj rautela
Vernon Taylor
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
