Question about IBM ThinkPad R31 2656 Notebook
Can you add DDR3 for memory? - IBM ThinkPad R31 2656 Notebook
    Guru:
  • 374 Answers
You cant add DDR3 because the motherboard will not support it.
I would look at buying some standard PC133 SDRAM. Its really cheap online on ebay or amazon.
Posted on Sep 10, 2010
What is the process to add additional memory to my 4GB laptop?
You will need to follow these steps:
1. Determine which type of memory your laptop uses (DDR,DDR2,DDR3)
2. Determine how much memory you would like to add
3. Purchase the memory
4. Install. The memory is typically installed in the underside of your laptop. You will have to take the bottom off, take out the old memory, and install the new one
May 31, 2015 | Computers & Internet
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Max ram for HP Pavilion dv6 Notebook PC
Is it Pelham Sloane PS1500? 4GB
Is it HP Pavilion dv6 Notebook? 16GB
HP site indicates as:8GB DDR3 System Memory (2 Dimm)
12GB DDR3 System Memory (2 Dimm)
16GB DDR3 System Memory (2 Dimm)
Oct 08, 2012 | Pelham Sloane PS1500 PC Desktop
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)
Maximum Memory: 32GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
Aug 19, 2012 | Gateway Desktop / Intel Core i3 Processor...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
Add memory to lt2802u netbook.I am A+ certified.
Memory Type: DDR3 PC3-10600, DDR3 PC3-8500, DDR3 (non-ECC)
Maximum Memory: 2GB
Slots: 1
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500 with a maximum of 2GB per slot.*
Here is a youtube video for how to .. http://www.youtube.com/embed/J-WB0SdfEnk
Jul 08, 2011 | Computers & Internet
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
In acer 4736 two keyboard keys are not working . how much cost it will take? and i want to add 2gb ddr3 ram also.what is the cost for that
The keyboard for the acer should run about $35 and the DDR3 memory should be less than $50. Both can be ordered online.
Aug 14, 2010 | Acer Computers & Internet
Memory Upgrade
Depends of your buget, Extra 4 GB DDR2 800 = $35 (total 8GB) I Have 4GB installed now seems fine, but all of this is necessary?
what application do you need to work?
Mar 27, 2009 | Computers & Internet
IBM ThinkPad R31 2656 Notebook Logo
26 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
