Question about GE Monogram ZDP48N4GHSS Stainless Steel Gas Kitchen Range
The burner electrode will not turn off...it just keeps clicking and the red light on the burner control is on
  • 101 Answers
Need spark modual
Posted on Sep 10, 2010
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
When the burners come on the electrode keeps clicking. If I unplug it I can light it manually
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 28, 2011 | Cooktops
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
Electric and battery working fine but gas will not come on. It keeps clicking and then the red light comes on
Assuming this is on a travel trailer / RV, correct?
The red "check" light indicates that the fridge was not able to detect the presence of a flame from the burner area. This could be due to low LP gas pressure (causes different flame size), no LP gas (tanks are exhausted / turned off), damaged wiring going to the igniter / sense electrodes, defective gas valve, or damaged igniter / control board.
Aug 18, 2010 | Refrigerators
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Nov 15, 2007 | Viking VGSC366-6B Gas Kitchen Range
GE Monogram ZDP48N4GHSS Stainless Steel Gas Kitchen Range Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
