Question about Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Clock doesn't run - Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Your timer has a manual override. Does 240 circuit work when manual override is turned on? If 240 V circuit works but clock doesn't, then you need another clock.
WW Grainger sells clock motor for $16
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
If circuit doesn't work when timer override is on, then check circuit breaker.
Both legs of 240 V breaker must be hot for T-104 clock to work. A 240V circuit can appear to have power if only one leg of the circuit breaker is hot. Test breaker or move wires to another same-size breaker to test for sure.
Posted on Sep 10, 2010
Does alternator have anything to do with car cranking
No, the alternator doesn't clock in for work until the engine is running...
Nov 09, 2012 | Toyota Cars & Trucks
Oven doesn't get hot
if there is no clock then its the heater element gone ok if it has clock make sure clock is set ok
Oct 15, 2012 | GE Ovens
Which fuse on a 2001 Carrrera runs the digital clock
The fuse center diagrams are in the owners manual, Porsche doesn't allow free downloads of the manuals, so we do not have one, otherwise i would share the info with you sorry.
Sep 05, 2012 | Porsche Carrera Cars & Trucks
The system for sr5019 uk is very slow, and doesn't always runs smoothly, also, my clock keeps switching itself off when I logoff.
You need to replace the cmos battery. It is the little nickel sized silver disc on your motherboard. It will have the number 2032 etched on it. That is the size of the new battery you need to replace it with. Once you do that you need to optimise your bios settings or have someone do it for you.
Sep 01, 2012 | Compaq Computers & Internet
The projection part started to flicker one day and now it doesn't work.
if you get display on clock it may be the bulb, if it is totally dead check batteries. here is a manual for the clock
www2.oregonscientific.com/ulimages/manuals2/RM818PA.pdf
good luck
Jul 12, 2011 | Oregon Scientific RM 818P Clock Radio
Rmz450 08 looks like cam has spun on gear how do i check
The manual shows the gear as having 3 slots and 1 hole that lines up with the tip of the cam lobe. If the engine is at TDC and the timing marks level w/ the top of the head, the exhaust cam gear hole and lobes should be at 10 o'clock, the intake cam at 2 o'clock.I have had this happen on a YZ-F before, it doesn't have to be off but a degree before it doesn't run right. Good luck!
Jun 09, 2011 | Suzuki VT750DC Shadow Spirit Motorcycles
Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
135 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
