Question about Microwave Ovens
We have a Russel Hobes kettle modell 3123US . Last time we use it, we discovered that after we pushed the switch to boil the water, it started working and after a minute the switch jumped up and stoped warming the water. Since then it doesn't work at all.
  • 99 Answers
SOURCE: kenwood kettle sjm350, does not seem to be boiling
Dear,
When heater coil is fuse or burning or broken .So you need a new heater.Replace old or damage uniteand buy new one.
Posted on Dec 06, 2009
wiringlunati
  • 576 Answers
SOURCE: New kettle leaves a metalic tast to water after boiling.
Try different water. If you use tap water normally, buy a jug of water at the store. The pH may be wrong (particularly if it is too low) and leeching metal from the kettle. Good luck.
Posted on Jan 05, 2010
MicrowaveSvc
  • 9086 Answers
SOURCE: lcd display goes out then when i uplug it it works
This is simply a rebranded Sharp R-1750, 1751, 1752, 1754 unit.
We regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Nov 26, 2010
  • 403 Answers
SOURCE: OK, so our microwave stopped working. All the
the problem could be with 2 component. The diode or the magnetron. normally when the diode goes bad, the microwave will make a humming sound. The microwave will tend to sound almost normal when its the magnetron. Or sometimes it will make a sparking noise when put to heat.
Posted on Feb 26, 2011
Testimonial: "The microwave sounds very normal when running (ie. the only noise I hear is the fan... well and the turntable makes a little bit of noise..."
dcramer531
  • 1654 Answers
SOURCE: i turned on the cordless
Yes, if your worried, use a fine emory paper to clean off the tarnish from the heat scorch. You may have shortened the life a little on the element but it is fine as long as it is not spalling, of flaking.
Posted on Mar 24, 2011
When you plug in the light comes on but kettle does not boil model no 15075 buxton white
If this is a kettle then sounds like the Element has gone, buy new kettle....
May 03, 2011 | Russell Hobbs Microwave Ovens
I turned on the cordless electric kettle without water! the metal rod inside the kettle turned black? was it burnt? i tried boiling water again and it worked. but is the metal rod toxic or not? can i still...
Mar 24, 2011 | Microwave Ovens
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
How do you desalazize kettle?
If by desalazize you mean remove the deposits which build up from the minerals in your tap water, the easiest way to do it is with white vinegar (most vinegar will work but white is best for cleaning).
  1. Fill kettle with a mixture of white vinegar and water (about 50/50 but it doesn't have to be exact) until it covers as much of the deposits as possible.
  2. Heat the kettle until the liquid boils
  3. Let the kettle sit with the liquid in it for 3-6 hours
  4. Empty and Rinse
  5. Fill kettle with regular water, boil, and empty to get rid of any lingering vinegar taste.
If the deposits are especially thick, you may need to repeat steps 1-4 before moving on to step 5.
Mar 01, 2011 | Microwave Ovens
I want to buy a replacement KETTLE only, for my black, RH Quick 2 Boil Kettle, any suggestions. Nick
I would contact Russel Hobbs and see if they actually sell them separately. When you are online to them there should be available, a list of retailers that stock the item you want http://www.amazon.co.uk/Russell-Hobbs-15198-Quick-2-Boil-Kettle/dp/B003DNSQPC
I see what you mean, it is part of a set. I bought one, in dark grey, and I am sure they sold one in black, from Wilkinsons. It was Quick Boil Kettle only, on a standard connector stand. TJ Hughes also stock them!
Hope that helps.
Dec 30, 2010 | Microwave Ovens
I have a Russell Hobbs kettle which is now leaking. Can it be repaired. It is several years old but still works well.
The coils of Russel Hobbs outrun the shell jar for sure as the corrosion in the kettle would have caused the leak.
The best can be to get the kettle welded with metal, use gas welding to mend up the leak and use a good grinding tool to polish off the suface.
Wash and clean/scrub well to remove all flux /dirt before you use it.
Boil water three times to discard before you use it.
You can continue to use the Hobbs.
Aug 27, 2010 | Microwave Ovens
Jan 05, 2010 | Microwave Ovens
Can i use water boiled from microware to make formula milk for a baby that is 1yr old
I wouldn't recommend to use the microwave to boil water. Here you can read the reason why: http://www.snopes.com/science/microwave.asp
Water can 'explode' when heated in a microwave under certain conditions. Best way to boil water should either be using a water boiler or an old-fashioned kettle.
Jun 17, 2009 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
