Question about HP Photosmart D7160 InkJet Printer
Replace yellow ink cartridge twice , same error message saying empty ink cartridge.
  • 1 more comment
  • diesel290 Sep 10, 2010
    Model: HP Photosmart C7180 All-in-One
    Thanks Michael34 for quick response, model is HP Photosmart C7180, can you clarify
    button - resume and
    button -cartridge
    I've got an 'ok' button, no 'cartridge' button,.
    I added a comment to my first question when I realised the model was identified as HP Photosmart D7160.
  • diesel290 Sep 16, 2010
    Hey ginko,
    I think it's stuffed, tried your first 2 solutions, but when I rang HP to see about servicing it, they told me and I've read this before, that it cannot be serviced because it's a corroded yellow sensor and cannot be replaced because all the printheads are together as 1 unit. Making the Photosmart C7180 as HP say un-repairable, any ideas?
  • HP Master
  • 19,396 Answers
Hi.
To start ensure that you did reset the printer by disconnecting power cord for about five minutes. Test different kind of cartridges. Also try reinstalling printer software.
The cartridge is not being detected. This may happen for different reasons:
1 - The chip on cartridge is defective. Test using a replacement cartridge.
2 - Poor contact because of dirt on contact plate inside ink carriage. Clean the metal plate contact located inside the ink carriage, in the malfunctioning cartridge slot. Use soft cotton and isopropyl alcohol or circuit cleaning solution. Do not use water or detergent.
3 - Broken contact from print head. The contact at the back of print head may be broken. First test is done ensuring that there is continuity between cartridge slot contact and connector at the back of print head. Call service at the number listed on owners manual if you are in this case.
Posted on Sep 10, 2010
Here is the reset procedure for clearing this message. First, unplug the power cord and hold power and resume buttons. Now, plug the power cord back in and release the power/resume buttons. Open the front door of your printer and hold the cartridge and resume buttons. Now, press power and then release all buttons after the beeps and press cartridge once and then press resume.
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Ink system failure error telling me to refer to printer documentation error 0xc18a006
The "Ink system failure" error is caused by air in the ink feed tubes, this happens if you use poorly filled cartridges or allow you cartridge to run all the way out. We have a step by step guide to purge the ink feed tubes posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get your printer back going in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2010 | HP Photosmart C6100 All-In-One Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
"Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Jun 26, 2009 | Epson Stylus Photo 950 InkJet Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Ink empty yellow error message even after ink has been replaced
the mechanism on the cariage is faulty. It cannot be repaired by you the user.
Jul 08, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart D7160 InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
