Question about GE (PSS26MSRSS) Side by Side Refrigerator
Yes i have a g e side by side refrigurator it was low on freon it takes 134a i was told it only takes about 8 to 10 oz of freon what should the low side pressure run at please
  • 101 Answers
If its under five years its in warrenty, it takes less the 8-10. about 5.5 oz.
Posted on Sep 10, 2010
TRUE REACH IN MN TSSU 60-16 LOW SIDE IN NEGATIVE PRESSURE HUIGH SIDE AT 100PSI SYSTEM IS RESTRICTED WHERE IS EXPANSION VALVE?
This is a cap tube system. Try replacing filter, they often become clogged due to the oil used in the system. Cap tube can be clogged as well. could simply be low freon level. Evacuate the system and weigh in R-134A, amount is listed on model sticker. Also remember that when you attach gauges to the high side you are removing up to 2 oz., or more from circulation. Use a gauge with a short hose, like 6", on the high side. Be sure to bleed your low side hose with 134a before attaching to prevent moisture entering system, that also turns the oil to acid and deteriates the filter and clogs cap tube.
Oct 27, 2013 | True Refrigerators
What kind of freon does my 93 subaru legacy use and how many
It probably takes R-12 refrigerant. R-134a didn't come out till 1994. It takes 32 oz. to fill from empty. Might want to check and see if it can be converted to use R-134a.
Jun 16, 2011 | 1993 Subaru Legacy
Does anyone know how many cans of freeon it takes to charge the air conditioner
It depends on what size cans of freon you are getting and if the system has been retrofitted for R-134A refrigerant (1992 came originally equipped with an R-12 system). The factory specifications call for 1.8 Lbs. of R-12. If it has been retrofitted for R-134A, the general "rule-of-thumb" is 85% of the R-12 specification is needed to charge the system with R-134A. So if we do the math: 1.8 Lbs (R-12) X .85 (R-134A) = 1.53 Lbs. R-134A needed for a full recharge (providing the system is COMPLETELY empty. Then you will have to find out how much is in each can that you plan to buy and do the math to figure out how many cans you need. (some have 12 oz., some have 14 oz., some have 16 oz., some have 19 oz. and some have 22 oz.)
Jun 16, 2011 | 1992 Honda Accord
How many pounds of r134 and how much oil ozs.
somewhere around 1.6 pounds (1lb.14ounces) of R134a if system is evacuated and 3 ounces of oil with new compressor.
keep pressure on the low side around 34-37psi & it should blow snow. Below are normal car AC pressure readings with 134A.
  • Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
  • Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI –
  • Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
DIY recharge kit:
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold – STOP don’t overcharge the system.
Thank you for using fixya and be safe.
Jul 19, 2010 | 1994 Chevrolet S-10 Blazer
A/c compreser is it hard to change on a 90 lexus ls
yes and you need special tools and equipment to properly vaccuum out the sytem before recharging it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Oct 31, 2009 | 1990 Lexus LS 400
How much freon does a 2002 dodge intrepid hold
It does not use Freon it uses 134a and it depends on condition of compressor and how much is in it. I would go to Auto parts store and buy 2 cans of 134a with the gauges on them if you read the can or the gauge it shows you when it is full. Make sure you connect to the Low side of connection.
Sep 25, 2009 | 1998 Dodge Intrepid
Where does the freon go for a 99 expedition
Hi .. I just ran into the same problem .. I have a 2000 Expedition with the 5.4L engine .. the low side port is located on the passenger side of engine compartment just below the black metal bracket that contains electrical connections right in front of the firewall... you have to reach under this and locate the low side (larger line) and feel for the connection .. it is right in front of the accumulator .. There are two heater hose that hide the port .. you have reach under these to unscrew the port cap which is black .. you'll have to do this by feel .. I have found that you can by R134A charge with dye and leak sealant helps with small leaks .. if the system takes more than two cans be usre to add refrig. oil .. hope this helps
Jul 19, 2009 | 1999 Ford Expedition
Freezing
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
Aug 29, 2007 | Amana 16.8 cu. ft. / 476 liter Upright...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
