Question about Samsung SW62ASP Top Load Washer
Doesnt dry shows dE when you put it on make anoise as if it to drain water plz help
    President:
  • Samsung Master
  • 1,932 Answers
dE = drainage error,
empty the filter, check pipe outlets are clear , check the pump
Thank You
Posted on Sep 10, 2010
My samsung washing machine model SW50V3 showing dE error after its full of water, its not spinning at and even not draining as well, plz help thank you.
Did you go to Samsung site and inquire re the significance of the DE error?The machine is telling you where the problem is. Use the info and check it out.
Sep 17, 2017 | Samsung Washing Machines
When we are rinse and spin why are showing dE
If not draining the water is the 'DE' a drain error? not draining water?
Jun 01, 2016 | Washing Machines
Water is running in and draining right back out. Leaving the dishes completely dry and dirty. I found a part laying on the floor when I took the cover off. I put it back where it came off of and now this...
Was it the float? try this empty machine put 1cup of vinegar or CLR and let it run through machine and clean jets and spray arm as well as soap dispenecer,You may want to try cascade they have rechanged it .Try this and let me know thanks
Jul 29, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
Para un mitsubishi endevor 2005,la salida del agua
The water is clear condensate water from the air conditioner evaporator drain. You'll notice that the water doesn't contain any antifreeze or odor. Keep in mind that running with the ventilation control selector in the defrost position also runs the air conditioner. The foam seal around the drain tube and the fire wall has deteriorated allowing water that is blown back against the fire wall around the drain tube to enter the passenger area of the vehicle. You can see the hard plastic drain tube protruding low on the engine side of the fire wall. It's about an inch or so long and a little better than a half inch in diameter. The fix is easy and permanent. Cut a 2.5' patch from some rubber gasket material, it can be round or square doesn't matter. Cut a round hole in the center of the patch that is slightly smaller than the tube. Slather one side of the patch with marine sealant and slide itover the tube with the sealant side tward the fire wall pressing the patch against the firewall. Now use a wet dry vac to extract as much of the water from the passenger foot well as possible an wait about a week or so for the carpet and padding to dry.
Feb 25, 2010 | 2004 Mitsubishi Endeavor
Machine will not start, has anoise when I lift the lid and has DE
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG - http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 05, 2009 | Washing Machines
How do I get the water out of my washer that won't drain?
First thing to do is to lay the drain hose down into a bucket or similar and let the water syphon out of the m/c, once you have got rid of the water, you can open the door and remove the clothes.
Then check the filter for a blockage, it is usually located at the bottom right of the m/c behind a removable plastic cover, unscrew anti clock and clean, refit and then pour some water into the drum , and select the drain prog, see if the water pumps out o/k, if it does then you have cracked it as they say..
If the water still does not pump out then there is a blockage elsewhere or the pump is not working for whatever reason, further investigation will be req'd.
Plz rate this solution.
Thanks,and merry xmas
Dec 19, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Help again
If you drop your phone in water, there's no cure it will drown,
Water and electrical devices, whether AC or DC do not mix very well.
The only thing you can do is take all the removable parts off, and dry them using a low heat hair dryer. Some bits and pieces can be changed, but it will end up costing you just as much as buying another phone, near enough anyway.
I would put it down to, a bit of bad history best forgotten and I would buy another phone. It might work OK after a while of leaving it in the sun, but in the end it all depends on how long the phone was in water.
Feb 27, 2008 | Nokia N70 Cellular Phone
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Samsung SW62ASP Top Load Washer Logo
133 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
