Question about Singer Inspiration 4220 Mechanical Sewing Machine
I've rethreaded the machine mulitple times and it keeps bulging up on the botton around the bobbin and I keep having to lift the small clip to reinsert the black part where it holds the bobbin. My thread keep breaking and I've kept havin to rethread it and readjust the tension, doesn't seem to work it only gets tighter. i'm soo frustrated and ready to give on Singer completely.
    Genius:
  • 1,788 Answers
Take a deep breath and read page 67 of your manual, it is your top threading that is causing the problem. On page 67 it gives troubleshooting hints, like making sure that you are holding the thread ends when you start to sew, look for a bent or burr on your needle. Replace needle. If, you do not have a manual go to singerco.com and download one for free.
I had the same problem last week and swore I had threaded my machine right, then I looked at my manual, whoa nellie!, I missed a guide and I have been sewing for 50+ years.
Posted on Sep 11, 2010
Thread presser foot juki serger
try a new needle
rethread the machine top and bobbin
make sure the bobbin is not warped or damaged
make sure the bobbin is inserted in to bobbin case correctly
clean under the needle plate and in the bobbin area for lint
if the problem still happens,, then it would be a good idea to have the machine checked for a timing problem
Sep 28, 2013 | Sewing Machines
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
I have a Pfaff 418 and suddenly the bottom thread keeps snapping after about 5cm. I've altered the tesion & the timing and it's still happening. Any ideas??
try rethreading the machine
clean under the needle plate & in the bobbin area for lint or threads
if these suggestions don't help, then the machine needs to be checked
to see what wrong with it
May 29, 2012 | PfaFF Sewing Machines
I have a Janome mc 6500 and the bobbin thread keeps getting stuck around the feed dogs?
clean under the needle plate area for lint or threads
try rethreading the bobbin,making sure the bobbin is inserted correctly into the bobbin case.
May 16, 2012 | Janome Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
Why does my 9000 keep jaming. I had it fixes and the problem still excist. I find that it balls underneath yet there seemsto be nothing uner in the bobbin case anywhere. I am tires of distroying towels...
What did they fix on the machine? Did they change the bobbin case? Many times the bobbin cases get burrs on them from broken or broken needles. Also the position bracket, (the elbow shaped piece of metal) that keeps the bobbin case from spinning around, has to be positioned correctly. Thread up the machine, put a small piece of cloth under the pressure foot, and turn the handwheel by hand, in the forward direction, and watch the upper thread as it comes around the bobbin case for every stitch, and see that it flows smoothly. If it hangs up any point, the problem might be the bobbin case or the position bracket. Also check the threading. Many times customers assume that the machine is threaded correctly and it's not. Be sure and rethread anyway. And make sure that there is no thread caught between the tension disks.
Apr 30, 2011 | Janome Memory Craft 9000 Computerized...
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
When threading my Viking sewing machine., the needle won't pick up the thread. I.ve used it 15 years. This is the 1st time this happened. Help...
Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
Apr 26, 2008 | Husqvarna Viking 1
Singer Inspiration 4220 Mechanical Sewing Machine Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
