Question about Rinnai Toyostove Direct Vent Heater: Laser 56 Toyostove Direct Vent Heater
Have laser 56 that stopped running today. when I turn it on all the lights come on, but do not blink. auto temp display reads 49 and hi but unit will not run. when i unplug thermostat wire from back of unit, fan comes on and runs, temp shows 49 and lo. No ignition. left it on all day still nothing. noticed that relay on back circuit board "sparks" when i plug and unplug thermostat wire. Any ideas? i live in rural alaska and will be needing heat pretty soon.
  • 905 Answers
Hello Leigh,
With the heater turned on, you should be able to hold the hour and minute buttons at the same time for a few seconds, and get into the manual operation mode. If you are able to get into this mode, then you likely just need another thermostat / sensor. If you cannot get into the manual mode, then you are looking at a controller fault, and you will need to contact the nearest dealer.
BTW, when unplugging the tstat, LO is normal. But HI should only be present when room temperature is above 95F (give or take a couple degrees). Not sure what to tell you about the sparking relay. If the cover is translucent / clear, you will see it as it makes its connection. Otherwise, something bad has likely occurred, perhaps the board faulted. Again, contact your dealer.
I was only able to find 1 dealer / service center in Alaska:
Rural Energy Enterprises
800 770 7330 Ofc
888 408 7330 Fax
Posted on Sep 10, 2010
Dream Maker Spa lights BLINKING
possible bad heater element or temp sensor or recirculation pump
Mar 06, 2013 | Dream Maker Spas Pool & Spa
Tip
Wiring Diagram Kawasaki GPZ 750
Kawasaki GPZ750 (ZX750) Turbo North American models.<br /><br /><img src="suzman_10.JPG" /><br /><br />1 - Right turn <br />2 - High beam<br />3 - Warning light<br />4 - Headlight fail<br />5 - Neutral<br />6 - Left turn<br />7 - Boost Guage <br />8 - Tach light<br />9 - Tach/volt switch<br />10 + 11 - Speedo lights<br />12 + 13 - Illum. lights<br />14 - Spare connectors<br />15 - LCD + warnig lights<br />15 + 16 - LCD illum<br />17 - RF indicator<br />18 - Horns<br />19 - Headlamp<br />21 - LF indicator<br />22 - Reserve lighting unit<br />23 - Hazard switch<br />24 - Indicator switch<br />25 - Horn switch<br />26 - Dimmer switch<br />27 - Starter lockout switch<br />28 - Neutral switch<br />29 - Side stand switch<br />31 - Oil pressure switch<br />32 - Alternator<br />33 - Regulator<br />34 - Solenoid<br />35 - Starter<br />36 - Battery<br />37 - Junction box<br />38 - LR Indicator<br />39 - Stop/tail lamps<br />40 - Stop/tail lamps<br />41 - RR Indicator<br />42 - Injectors<br />43 - Engine temp switch<br />44 - Boost sensor<br />45 - Fuel pump<br />46 - Air temp sensor<br />47 - Throttle sensor<br />48 - Main pump relay<br />49 - Fuel injection control unit<br />50 - Rear brake switch<br />51 - Pick-up coils<br />52 - Ignition control unit<br />53 - Coils<br />54 - Spark plugs<br />55 - Fuel level sensor<br />56 - Front brake switch<br />57 - Starter/engine stop<br />58 - Ignition<br />
on Nov 22, 2010 | Motorcycles
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
We have a MXZ-3A30NA that does not seem to be cooling down the house. Indoor temps are reading 75 to 78 degrees and the units are set at 65. We have gone through the book and have followed the check list...
Hi!!
Check the following:
Make sure the filter and the evaporator coil are clean. Also check condenser coil in the outside unit is clean.
When unit is turned on there should be (on the led display, inside unit) one green light on for the blower and another one for the compressor, both lights should be ON untill the unit reaches the preset temp. If the light for the compressor (usually the light on the right side) does not stay ON, check the outside unit.
On the outside unit, check that when turned on, both the fan and the compressor kick in and stay running. If the fan motor stops, the compressor overheats and the thermal proteccion shuts it down to prevent damage. Also, if the R22 gas is low, the low pressure switch prevents the compressor from running.
Good Luck!!
Aug 04, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
49 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
