Question about Kenmore 74822 / 74824 Top Freezer Refrigerator
Water leaking from the bottom of refrigerator into the floor, I have to weep the floor every second day.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE
You will need to get that panel out of the way to see and clean out the defrost drain.
Click Here=>Leaking Refrigerators
I am here should have questions, Thanks John Tripp Appliance 911
Jul 23, 2014 | Maytag 22 cu. ft. Bottom Freezer...
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
AC is leaking water onto the floor on the passenger side, some said the drain line could be plugged?
Yes, the weep drain. Inside the engine compartment, on the firewall, passenger side, half way between top and bottom of firewall. Small rubber tube comes out, then does a 90* turn towards the ground then just stops. You can remove the weep drain and clean it, or use wire to "poke" around and break up the debris. I suggest removing it.
Jul 17, 2010 | 2006 Chevrolet Impala
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaks from below the fridge a couple times a day?
There are several sources of water from within your refrigerator. The most likely source for the frequency you are experiencing, "couple of times a day", is the defrost system.
When your refrigerator defrosts, a heater that surrounds the evaporator piping behind the freezer back wall comes on which melts the frost on the coils causing the water to run into a drain below the evaporator. This drain can clog up with foreign particles accumulating in the drain. The clogging can cause the drain to spill over into the floor of the freezer and run out the door along the bottom of the freezer door through the door seal. This will usually leave an ice sheet on the floor of the freezer. If you do not have an ice sheet...the drain is not clogged.
The second method by which water ends up on the floor is a broken pan beneath the refrigerator intended to catch the water as it leaves the drain in the freezer. To test this, use a turkey baster and pump water into the freezer drain at the rear bottom of the freezer behind the wall using the holes in the wall. Watch under the refrigerator to see where the water ends up.
Performing these actions will lead you to the solution.
Nov 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water weeping out vents in lower back of freezer compartment
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Kenmore 74822 / 74824 Top Freezer Refrigerator Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
