Question about ASUS Computers & Internet
I have an asus laptop !+ all of a sudden when i am typing ~eg-where m is is also the No 0~ i has the No 5 alongside it & so on & i cant fix it so when i type i get the letter i type ~very frustrating -can you help me please ~Jim
  • 532 Answers
Check to see if the NUM Lock key is pressed.
Posted on Sep 10, 2010
I have an iomega 31868500 external hard drive I haven't used in years. I now want to use it to store files from my wife's Toshiba laptop running Windows 7.
Hi Jack
It would be pointless having a hard drive fixed to Read Only.
I don't think there is a switch setting to set as Read Only.
The original Iomega (early days) removable cartridge drives had a plastic tab on the cartridge to allow it to be write protected (RO).
So perhaps the Iomega Enclosure (Interface electronics inside) is getting out of date.
The oldest part of your drive will be the Enclosure & USB port.
I would suggest you open the enclosure and take out the actual hard drive. Should still be good to use.
Drives are either 2.5" or 3.5" Size Standard.
Eg Pocket drives are 2.5" size, Slower operation as they use 5 volt only. One bump during use can kill them!
3.5" use 5v & 12v & spin much faster (3500 to 7200rpm) for high speed transfer. Eg Movie Streaming / Fast Backups and are more robust.
The internal connector will either be the older IDE / ATA type connector Or
The new universal SATA connector (serial ATA much smaller)
You will need to determine this.....
The Fix:
The most convenient enclosure these days would be a DOCK type that allows you to plug in both 2.5 & 3.5 SATA drives. AND use USB 3 as a faster Future Proof Hard Drive
Then you can plug one in for Movies and another for Music and a third for Backups. Each drive purchased separately.
Eg 3x 1TB should be cheaper than 3 separate enclosed drives.
I'm sure there is a dual DOCK also for the older ATA connector.
But all future Drives will be SATA.
Once you determine what connector your drive uses then you can plug it in to the more modern housing and format the drive for Windows NTFS or FAT32 (Windows & Mac & TV's)
Cheers
Good Luck
EG: SATA
Amazon com ezDISK EZ0330 USB3 0 hard drive docking station support SATA II...
https://en.wikipedia.org/wiki/Serial_ATA
IDE Connector / Adapter
Vantec CB ISATAU2 SATA IDE to USB 2 0 Adapter Supports 2 5 Inch 3 5 Inch 5...
Amazon com SATA PATA IDE Drive to USB 2 0 Adapter Converter Cable for 2 5... Serial ATA Wikipedia the free encyclopedia
Connector
Parallel ATA Wikipedia the free encyclopedia
Bare Hard Drives: SATA & IDE
They all work on Windows or Mac (After Formatting)
Search Results for Western Digital hard drives at MacSales com
Feb 23, 2016 | Toshiba Computers & Internet
Sometimes my asus eee pc 1001px will not log on to windows 7. Other times it will but the keyboard wont work so i cant enter my password or use the F8, F9 Keys. I cant fix this at all. Any help greatly...
Hi patodonovan
If you can afford it try to buy an USB keyboard and use that one instead of your laptop keyboard .It will be much reliable too especially if you play or type a lot .
Aug 26, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Some of the keys, eg. 0 & 1, do not want to work. When I click on "start" with the touch pad the window does not stay open after it comes up.
Try a warm boot.
Press:
Alt + Ctrl + Delete
and this will bring up your task manager. Click on restart computer. Sometimes rebooting will cure these types of problems. If it dont, message me and I will be happy to further assist you.
Regards,
Nico
Jul 09, 2011 | MSI Wind U100-030US Laptop
I got an ASUS Laptob X5DIP Series HDD: 500GB memory: 3gb and there is a webcam inside of it but i cant find anywhere on the computer to configure it, it works but its inverse upside is down so i want...
Hi there. This normally happens when you do not have the driver installed for it.
To fix this , type up you ASUS laptop model number on google followed by Webcam Driver. Once the driver has been found, download and install it. Restart your Laptop and it should work.
Here is the ASUS website and simply filter by model number.
http://support.asus.com/download/Options.aspx?SLanguage=en&type=1
Rate and Comment, thank you.
Apr 14, 2011 | Office Equipment & Supplies
I have an asus eee pc 900 notebook, my daughter has pushed something & now when turned on displays the windows xp loading screen, then displays a page that explains windows did not start successfully I...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule when you restart then defragment your hard drive
hope this helps
Jan 12, 2011 | ASUS Eee PC 900 Notebook
How do i change my password on my asus wireless router?
I got your issue, Inorder to change the security on your router follow these steps,
1. Open your browser (eg: Internet Explorer), clear the address bar and type 192.168.1.1 and hit enter, You will be logged into your asus router setup page
2. Click on security , on that page
3. changed the security password to your wish and then save the changes which you have made
Please follow this, it will work
Thanks & Regards
Prema
Oct 14, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
My asus 1000hp netbook has a locked keyboard, and can't log in .
Keys 7, 8, 9, 0, U, I, O, P, J, K, L, and M are permanently stuck as if Fn is pressed so it is in the number-pad mode. So I can't type the above keys at all. If I want to type 0 I would have to type M. Obviously I am using a different computer now, just in case anyone is wondering. So does anyone have any solution to this? Please help!
Aug 08, 2009 | ASUS Eee PC 1000H Laptop
The keyboard has suddenly got limited function
I have the same problem with an Asus Eeepc 900HA. I am trying to solve, if you solve firts write to me to jhonald@redesfx.com, thanks
Jul 11, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
