Question about GE Dryers
DHDSR46EE1WW Elec. dryer is shuting off with time still left on timer. Have heat and drum turns. Some times you have to re-start a cycle 6 or 8 times to complete. Could this be the start switch or the timer assy?
    President:
  • 1,554 Answers
Couldn't be the start switch but it is definitely the timer (part number WE4M271) if you can restart it right away after it shuts off. Otherwise it is a problem with either of the thermostats.
Posted on Sep 10, 2010
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
Jan 07, 2011 | Estate EED4300TQ Electric Dryer
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Hello there:
I would have to tell you that i dont think that the two would fail at the same time but it can happen but not too often
deffinatly replacethe timer and the heating element and this will solve the problem
also since you have the unit opened i would inspect all of the wiring for loose connections and moisture cause this will cause things like these to fail prematuraly ok?
I hope that this has peeb very helpfull for you
best regards michael
Nov 04, 2009 | Kenmore 659 Electric Dryer
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE DHDSR46EE1WW Dryers heating coil won't shut off...ever!
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Jun 14, 2009 | Dryers
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
65 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
