Question about Electrolux Washing Machines
I have a 2 1/2 year old Electrolux EWF 1090 that has simply stopped working. It is as if the power has been disconnected and the machine is dead. Was working perfectly the previous load. Can someone shed some light on what may have happened to it. Kind regards, Belinda.
  • achammer Sep 10, 2010
    There is definitely power at the powerpoint because I have plugged the hair dryer into the same point and it worked fine. How can I tell if the washing machine's power board is working. Regards, Brelinda.
  • 1,531 Answers
First thing to check is the main power supply and circuit breaker and make sure there is power there.
then check the wiring to make sure there is no problems with that.
last thing is to replace the main control board
Posted on Sep 10, 2010
  • seth adams Sep 11, 2010
    you have to test the main wires to the board it will be a red and black wire
  • Electrolux Master
  • 19,396 Answers
Hi Belinda.
Check the following:
Ensure that the circuit breaker for the washer is on.
Ensure that power cord is well connected.
Test the main socket using a different appliance.
If power plug is fused, replace the fuse in power cord.
If all that does not work, call the service number listed in the owners manual to get the machine repaired.
Electrolux EWF 1090 not starting or even locking door when start/pause button pressed. All buttons work and light up.
Bad idea turning machine upside down - water from the soap drawer / sump hose / filter can run into several electronics panels. Sounds like you may have problems with this - and a repair won't be cheap. Door usually locks if nothing else - yours doesn't . If machine is 6 years old or so - get estimate for repair, but look at new machine also.
Nov 01, 2017 | Electrolux Washing Machines
WHAT IS MEA'NT BY L60 ERROR CODE AT THE PANEL OF EWF 1090 ELECTROLUX WASHING MACHINE AND HOW CAN I SOLVE IT?
Hello - Are you certain the error code is L60? This manufacturer does not have any (L) error codes for any washer or other units.
Nov 30, 2012 | Washing Machines
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
Washing Machines Logo
275 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
