Question about Sport & Outdoor - Others
Removed barrel screw from rear of barrel----bits flew every where ------- need diagram to reassemble
  • Sport & Outd... Master
  • 3,083 Answers
First of all, I assume we're talking about a gun, possibly a ruger or recoiling weapon. If this is the case, the closest thing you will find will be at your Public Library, as far as diagrams go, unless you can get lucky and find one on the web. I've seen some pretty neat assembly diagrams of all kinds of guns at the library, and that's your best bet.
Otherwise, you will have to write the manufacturer and request one.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
Can someone show me a diagram of how to install the drum belt for haier hlp140e? I need to know proper route
home appliance repairs should be performed by a qualified service technician. unplug the dryer open the door, remove the filter. there should be a 10mm nut behind the filter. remove the cover on the rear of the dryer.remove the phillips #2 screws. remove the four plate screw, remove the plate from the drum then reassemble.
Apr 23, 2017 | Haier Dryers
Mossberg model 88 manual
Open the slide and make sure it's empty....and then close the slide halfway so the bolt is halfway in the eject port. That unlocks the bolt lug from the barrel. Unscrew the barrel take down screw. Remove barrel. If the take down screw is overly tight, use pliers with a leather or canvas padding to avoid scratching the screw. When reassembling it, just tighten it tight by hand. Use no tools. It's not designed to tighten with tools. Hand tight is perfect.
Jan 03, 2014 | Sport & Outdoor - Others
How can i remove the fan barrel from the head unit to clean it
with care. first remove the screws holding the covers, you will find them behind two or three small caps near the louvers and maybe under the filter cover. Completely remove the plastic face. Remove the screws holding the coil in place. You can only remove the left hand end as the right hand is connected to the pipework. remove the grub screw holding the fan barrel onto the motor shaft. Remove the screws holding the left hand bearing in place. At this point you should be able to withdraw the fan barrel. Take very real care how you handle the coil, for if you kink the pipes your machine will no longer perform without some major surgery. While the unit is dismantled , try cleaning inside the machine, removing dust and mould. Reassemble in reverse order
Mar 05, 2011 | Fujitsu 12C1 Air Conditioner
I received a new lower burr grinder part from SAECO for my machine but no instructions on how to replace it. I know how to clean and replace the removable grinder part that fits into this. Do you have...
Hi
If you only got the lower burr it won't work. They should be matching burrs.
If you don't do it right, you will damage the grinder. You need a #10 Torex bit.
Insert the bit into the screw in the middle of a very clean grinder. Turn clockwise to loosen. Once the screw is out, pull the burr out, but be careful. There are ball bearings and springs under the burr. Make sure that everything is clean before reassembly. There are 3 holes in the bottom of the grinder. The springs go into the holes first. Then the ball bearings set on top of the springs. Place the new lower burr on top of the springs. A washer and the corkscrew go in next. Insert the screw in and with the bit in place turn (with a little down force) clockwise until the screw drops into place, then turn counterclockwise. It should turn fairly easy. Once you start putting pressure on the springs, try to turn the corkscrew. There is a notch that it slips into in the bottom of the grinder. Once it locks into place keep turning the screw until you start to turn the burr. That should be tight enough. Now reassemble the top burr and adjust.
May 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
I have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
MSZ A12NA the inside fan is making noise how do i
It's a quite complicated procedure but i'll try to describe as best i can.
Below the air outlet there should be a couple of screws. They may have small tabs over them (purely for aesthetics!).
If you lift up the filter cover, remove the filters and remove filter cover (trying carefully not to break it... darn plastic!) there may be some screws above the air outlet.
Remove the fascia cover starting from the bottom. Pull it out over the louvre in the air outlet. It will be clipped at the top near the back. These can be difficult to undo. Once that's done, remove the cover.
For the next bit, make sure that the power is turned off to the unit. (power cord unplugged, isolator turned off or c/b off depending on power source)
Undo the screws on the power box.
Undo the screws on the drain tray and off the left side of the evaporator coil. (Big finned section of pipework). Make sure you support the evaporator coil as it's only connected with copper pipes which bend/kink fairly easily.
You'll need to pull the coil out a little (not too far) and take off the left hand rubber 'bearing' as such from the indoor fan barrell.
On the right hand side of the unit you'll find the fan motor (which is held in by the power box) There should be a grub screw that holds the fan barrell onto the shaft of the motor. This is usually undone with an allan key but have seen them with phillips head screws also. This grub screw might be in a few different places. It might simply be on the right end of the fan barrell or sometimes the righthand column of blades is missing a blade and the grub screw is accessed by putting allan key/screwdriver up missing portion. You only need to loosen the grub screw, not remove it.
Once loosened, the fan barrel can be pulled off the motor shaft and removed.
Once off, you can inspect it for obstructions or broken blades etc. To reassemble is just the reverse of these instructions.
Just a few things to note:
1. Be careful of the evaporator coil not to kink (or break!) the copper pipes or your a/c won't work properly.
2. The drain tray may have water in it if the a/c has been operating recently.
3. Make sure the power is off before pulling off the power box.
This can be a very difficult task and I would recommend having an assistant to help with holding stuff.
Hope this helps!
Jan 17, 2010 | Mitsubishi MSZ09UN Air Conditioner
Flash does not work on my Nikon D 80
My D80 had the same problem, I took it apart by first removing the base (make SURE you track which screw goes in which hole!), then remove the front shell (around the lens mount) but first remove the A/M lever by prying the cover off and unscrew it- pop the flash to remove the two small screws at the front of the flash rest point. Still keeping track of the screws? Now remove the screws holding the sides, you do not need to remove the battery side (it has another screw holding in deep inside the battery well). Now you can remove the rear shell - watch the flat ribbon cable, it is released by gently prying up on the thin black bit of plastic on the connector - I did say GENTLY. Now remove the side cover on the left (rear view). Check the tiny wires that are loop around the top from front to rear - I found one was broken. Find someone very good at soldering and solder it back. Now reassemble - you DID track which screw went in which hole? I also recommend that you photograph each screw removal and measure the length of the screws (mm - 4, 5, 6, & 8mm).
I too a bunch of pictures and am considering a take-apart page, but rather busy right now...
It is easy to break ribbon cables - be careful!
John :-#)#
Dec 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
How can i replace the key switch in a 01 Grand AM and will i need to replace the security mod too?
It depends if you want to change the key barrel or the tumblers, to remove the tumbler set put key in the switch, remove the beauty ring it just snaps on then stick a paper clip into the hole where you removed the ring or on the bottom of the barrel turn the key in reverse past accessories and pull tumbler set out. if you need to remove the barrel you will have unhook the battery then take horn cover off, pull the protective plastic tabs off the rear of the steering wheel and remove the safety tork screws and remove the air bag disconnect the air bag plug. next remove the three screws holding the horn ground ring and the plastic piece that separates it from ground put them in order next remove the center bolt using a steering wheel puller pull steering wheel next compress the plastic cover with the U shaped steering wheel clap and push the plastic dust cover down 1/4 inch next remove the center c cer-clip slide the clip off of the steering wheel shaft remove the dust cover remove the copper tangs on the right side of shaft and you will see a #6 tork screw remove that one screw and the barrel will come out, on some models it's the only way to get the barrel out. If this helps plese rate me. I am a better mechanic than a typest.
Aug 07, 2009 | 2001 Pontiac Grand Am SE
My pfaff synchromatic 1209 machine--the stop motion know keeps falling off. I have reassembled it but it will not wind a bobbin and only sews for a little while. Does it have a spring in there? I was...
You machine has a screw that fits the end of the shaft and the head pof the screw has broken. You can buy a new screw from a sewing machine dealer but if the whole assembly has come off you may need to take it to a dealer to have it reassembled properly. There is a spring inside which is very difficult to install.
sewman7
Aug 19, 2008 | PfaFF Hobby 4260
Sport & Outdoor - Others Logo
18 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
