Question about Singer Sewing Machines
Press on the preasure foot and the motor is trying to turn over to sew put it take a couple of monutes to sew
    Genius:
  • 1,788 Answers
Sounds like it needs a tune up, if it hasn't had one in a while, now may be the time. Check your manual and it may tell you where to oil it, If you don't have a manual go to singerco.com and download one for free. Good luck
Posted on Sep 11, 2010
Why does everything get hot except electrosurge wire tip for cutting?
A couple of possibilities:
1. Remove the belt. While using the foot pedal it is necessary to see if the motor moves freely without excess heat. If there is a problem the motor must be replaced or fixed.
2. Try to turn the machine without the motor attached by using the hand wheel. Does it move freely? If this is a problem the part that is causing the resistance must be found. Especially check the hook (under the bobbin case), needle arm and monitor moving parts.
3. Is the belt in good shape? If it is not so good then replace it.
4. While the belt is attached the motor must be cocked to allow the least resistance and most speed while the motor is running. This must be done carefully while the motor is running slowly. (foot control) The adjustment can be done most accurately this way.
5. Clean and oil all moving parts.
6. Make sure the bulb is the right size and not touching any of the metal surfaces.
May 19, 2015 | Sewing Machines
How do I just the tension on my Singer 621B
There is a nob for tension. Put scrap material under foot to sew. Dial tension run a couple of stitches that would be tight ,not good turn to right that loosens stitch. Keep trying till problem solved. Lots of patients .
May 20, 2014 | Singer 2263 Mechanical Sewing Machine
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
My older husky sewing machine runs on a couple of threads before stoping each time, it is not the foot peddle.
...most likely it is the foot control pedal. Try your on another machine perhaps. The control pedal is the only way power can get to the motor ....
Oct 16, 2013 | Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
My New Home sewing machine has been in storage for 2 years. When I press the pressure foot, the motor just hums. Can you help me?
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
Mar 30, 2012 | Sewing Machines
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Winding the bobbin
If you can't turn the spindle easily with your fingers, it needs a drop of oil. Use only one small drop, as excess oil will cause the tire to slip. After oiling, turn the spindle until it moves fairly freely and then engage it with the motor.
Mar 16, 2009 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
