Question about Golden Technologies Golden CompanioN II - 3 Wheel
HOW CAN i GET MORE THAN 3 HRS DRIVE TIME ON MY COMPANION 11 SCOOTER?
    Problem Solver:
  • 14 Answers
Please do not follow the above advice! Your Companion II scooter uses U1 batteries which are 35AH batteries. Using the batteries suggested above will not only lessen the time you can use your scooter, it will also void all warranties.
The amount of usage you get out of your batteries is determined by many factors. How old are the batteries? How long have they been charged? What is your weight? What type of terrain are you driving on? Are the lights on while driving?
Your Companion, with new fully charged batteries, should get you 15 to 25 miles to a charge depending on the variables listed above. When batteries first come from the factory, they are typically at 80% charge. It will take approximately 5 charges and usages for the batteries to achieve full charge. This is normal for most batteries.
My suggestion is to take it to a dealer and have them load test the batteries. This will help to determine if there is an issue with the batteries. If they test out properly there may be an issue with the charger. Please remember, we recommend charging batteries overnight.
It is always best to charge them for at least 8 hours. We have found many individuals attempt to charge batteries for two hours or so. From speaking to the battery manufacturers, they tell us this typically does no good.
Your Golden dealer will be your best resource to determine if there is anything wrong with the unit.
Posted on Sep 10, 2010
  • 37 Answers
I'm not to shure the dimensions of your two batteries but this is what i would do. (i go to high school so i have a bunch of time on my hands) Try some car audio batteries like these. http://www.sonicelectronix.com/item_17907_SHURiKEN+SK-BT20.html
http://www.sonicelectronix.com/item_17902_SHURiKEN+SK-BT35.html
you are probably going to have to copy and past the links. if these can rune a car stereo all day then they should run your scooter for way more than 3 hours.
Where can I get a replacement key for my golden companion 2 scooter? Mine is lost
You could use the search function on the Golden Technologiesto find your nearest dealer:
http://www.goldentechdealer.com/
or you might try contacting the Golden Technologies Technical Support Center directly at 1-800-624-6374 to inquire about a replacement key for your scooter.
May 22, 2011 | Golden Technologies Companion II Travel...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Removing carpet to clean it
Im not sure on this exact scooter (I have not come across one like yours in the UK) but most are simply attached to the scooter floor with velcro!
Feb 16, 2010 | Golden Technologies Companion II Travel...
We have an scooter an this scooter have an electronic's device's have self diagnostic an this scooter dont work an 7 times the green led is flashing an stop an repet again the cicle. we want know what...
If the batteries are charged and the brake is in the drive possition, it is possible that either there is a problem with the Wig Wag (forward/reverse paddle control) or the speed pot. Some ideas for you to look at.
Nov 10, 2009 | Golden Technologies Companion II Travel...
How to dissasemble golden companion II
Companion-2 scooters. Remove seat by holding up on seat lever and picking up seat at the same time. Then remove bolt from seat post and remove seat post. Remove rear cover. Unplug and remove batteries.
Jun 29, 2009 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Reversing thumb controls
Your authorized Golden Technologies, Inc. dealer can reverse the thumb lever controls so that when you push on the “left” lever, your scooter will move in the forward direction, and pushing on the “right” lever will move your scooter in reverse.
If you don't want to go to a dealer, any mechanic who is willing can make this adjustment for y ou. hope this helps.
Feb 14, 2009 | Golden Technologies Companion II Travel...
Companion II Scooter
Need to remove the five screws form the back side of the tiller. You can then tell if the adjustment lever has come off or the adjustment cylinder is bad.
Sep 21, 2008 | Golden Technologies Companion II Travel...
Golden Technologies Golden CompanioN II - 3 Wheel  Logo
144 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
