Question about Relic Watches
The crystal is scratched, can I fix that myself?
  • 4 Answers
If it's plastic try buffing it out with toothpaste
glass ? No much you can do except take it to your local jeweler
Posted on May 24, 2015
  • 831 Answers
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Posted on Sep 10, 2010
    2105(3). does this watch have an acrylic crystal or mineral glass?
    sorry but possibly only a jewelery shop could tell you .
    Feb 14, 2016 | Crystal Watches
    WHERE DO I GO TO REPLACE A CRYSTAL FACE ON A SKAGEN WATCH
    If the watch is under warranty it would cost you $32.00 to have it fixed.
    you can follow this link for more information: http://www.skagen.com/webapp/wcs/stores/servlet/ContentView?storeId=37082&page=customerCare_warrantyRepairs&nav=leftNav_CustomerCare&langId=-1&catalogId=26505
    The other option is to go to a professional watch repair person to replace or buff out the crystal if it's just scratched. The fees are around $25 - $50 since that watch has a mineral crystal. I hope this helps!
    Feb 14, 2013 | Skagen 589SSSB Ladies Steel Black Mesh...
    Watch lens scratches... Solutions to repairing?
    If you have a plastic crystal, you can use plastic polish (I like Novus #2, myself) to buff out small scratches. In a pinch, white toothpaste (not the gel kind) contains gentle grit and also will buff out some imperfections in a plastic watch crystal. Toothpaste is harsher than plastic polish, however, and may remove deeper scratches at the cost of creating some additional fine scratches.
    If your watch crystal is made of mineral glass, scratches cannot be easily polished out. In that case, your best solution would be to take it to a jeweler or watch repair facility to have the crystal replaced. Depending on the style of the watch, replacing a crystal can be as little as $15--or run to well over $100 for some diver's watches. If you're not comfortable with the estimate, get another one elsewhere. Crystal replacement is a high profit margin job for many jewelers. Not everyone is equally greedy.
    May 09, 2011 | Akribos XXIV Saturnos Skeleton Automatic...
    I have a Police Phalanx watch, black and rose gold effect. The glass has a couple of scratches and one of the rose gold markers has come away at the 10 o'clock position. Would it be expensive to repair...
    If the crystal of your watch is made of plastic, it may be possible to buff (or pay a jeweler to buff) it. Buffing a crystal is very inexpensive--sometimes free--and may eliminate the scratch, or, at the very least, greatly reduce its prominence. However, glass crystals cannot be polished in this way; the only way to fix chips or scratches is to replace the crystal, which can run anywhere from $15-50+, depending on the type of crystal and amount of work required to replace it and test for proper water resistance. Replacing the mineral glass crystals on some diving watches can be very expensive.
    Markers on a watch dial are ordinarily stuck on with little pins and/or a dab of adhesive. If the detached marker is still in the watch, this is ordinarily a fairly simple repair. The watch would be opened and the movement removed. Next, the jeweler would carefully place the marker back into position, probably adding a tiny drop of glue to keep it in place. A job like this can cost as little as $25, if it requires no replacement parts and you take your watch to a place that does a lot of watch repairs, as opposed to a general jewelry store that has to outsource the repair to a wholesale workshop.
    May 06, 2011 | Police Phalanx Watch 11599JS 02 m Watch...
    So, my Nixon The Banks has a pretty big scratch on the front crystal face. How do I go about getting it fixed or the crystal replaced?
    How deep is it? If you can, send me a picture - nat210790@hotmail.co.uk
    I have a Banks and when I had a similar problem, I managed to get it buffed out.
    Feb 22, 2011 | Nixon Banks Watch for Men
    Dear Sir, The main ticking seconds arm had stopped suddenly.Anything wrong ?? Moreover, I got very slight scartches on the crystal watch cover.How does this happen if the crystal is saphire and anti...
    mcdevito75 here, Hello David, Tag Heur a very fine watch, First I would make sure it is the seconds hand that stopped and not the Chrono. hand, I would also go over any instructions that came with the watch, about the light scratches on the saphire crystal, the crystal is scratch resistant to a point, and can occur almost anyway, rubbing up against something harder than the crystal itself, (certain Stones and materials) even if your in a dusty place scratches can occur on any crystal. Check with your warrantee, you should be covered.
    Jul 13, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
    Scratched crystal
    mcdevito75 here, If the crystal is Glass a replacement crystal may be your only choice, If Plastic It may be saved. Check with the watch repair service directory, right here on fixya. Bottom of this page, click on repair service directory then watches.
    Jun 30, 2010 | Swiss Army Wenger Swiss Army Officer's LS...
    Watch face glass cover scratched where do i get a new one from. La coste law6200L
    You can get from any experience watch maker work shop who do customized crystal or send your watch to La Coste Service center and if you are in chicago illinois
    we do customized crystal at
    AmFix Jewelry & Watch Repair
    203 N. LaSalle Street
    Chicago, IL 60601
    Ph: 312 641 7000
    Email: Info@goamfix.com
    Web: www.goamfix.com
    Sep 14, 2009 | Watches
    Replace mineral crystal in Zodiac Sea Dragon ZO-2201
    Its better you bring your watch to a service center ,Because equipped of all the tools.
    Hope it may helps;
    Jun 16, 2009 | Zodiac "Sea Dragon" Watch
    Watches Logo
    581 people viewed this question
    Top Relic Watches Experts
    Andrew Taylor
    Andrew Taylor
    richie46
    Are you a Relic Watch Expert? Answer questions, earn points and help others
