Question about Jet 3 Ultra Power Chair
Chair has full charge by light lit up, but once I pus joy stick foward the light go off and just one red light flashes quickly off and on. It started when I tool gear of to put in van and once I got to my destanation and took it out of the van, I put gears back in and now it keeps doing this even with the reset button reset. Can call me 828-403-1801
    Scholar:
  • 192 Answers
You could have a short. MAKE sure that all the wires are connected, these can also come loose if the machine is driven over rocks and rough terrain... Also, I would not post a phone number online, possibility for theft there.....
Posted on Sep 10, 2010
Jazzy select gt. batteries are good charger is new when charging the lights go from red to green and repeats, but if i hold the button one red one yellow ? i tested the batteries they are full but joy...
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
Jul 18, 2017 | Select Health & Beauty
My battery are full charge I checked the reset button and the lights on the joy stick flashes. What next to check. This unit is about 6-7 mo. Old
The number of flashes is a code for what is wrong. Go to the website of your chair and download the owners manual. It will have a chart of things to check
May 10, 2017 | The Health & Beauty
All red lights flashing. both battreys @13.5V 26V going to joy stick. Does't do anything.
Hello,repeat that to a service person.They should be able to give you a price for the job.
Oct 25, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Chair has 7 lights does not respond to joy stick ,new batts full charge, bought new joy stick no lights does not turn on at all help help iam lost
hi Dennis, i can help you but i need more info, firstly the name and model of the powerchair ?
Regards
Rob
Oct 23, 2015 | Health & Beauty
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
On off switch lights the red yellow green readings at full strength but continues to just blink when turned on.. get no response trying to use the joy stick. - the seat riser and speed buttons show no...
YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
Mar 07, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Lights Flashing Right to Left and will not turn off
That should have unlocked the controller. You might try disconnecting the power to the chair and then reconnect and try again. Start with just the joystick plug-in in the rear, and then try the main battery harness unplug.
May 22, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jet 3 Ultra Power Chair Logo
59 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
