Question about Sharper Image ICEflow Portable Air Conditioner
Missing the power supply. Where can I buy one?
Dell PC not switching to on, if we press switch on/off button it shows orange light and then it switched to off.
First possiblility is too much load on the power supply. Unplug the power connections to everything except the HDD you boot from. If it powers up buy a larger power supply.
If it still doesn't power up, it's a bad power supply. Check the output. You should have -5vac, +5vac, -12vac and +12vac output. If any are missing replace the power supply.
Aug 22, 2013 | Intel Pentium 4 2.40GHz 512/400/1.5V...
Hi, I have Plasma TV Power Supply Board. The model of board is: LJ44-00144A PS-506-PH. The stand-by voltage 5Vstb works just fine. When I turn on the TV the Stand-by let in front of it comes blue like...
I have the same problem. As I see, here is dead sub PCB with microcontroller on board. Small PCB with 26 pins, mounted verticaly on main, big power supply board. It is not available as a spare part. You must buy complete power supply board LJ44-001444A, as I have done.
Aug 09, 2011 | Philips POWER SUPPLY (41644158) Power...
Missing power supply
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Hisense TL1700 17 in. LCD Television
Missing part
Charger does't connect to DVD player.
Connects to battery. Built your own, Radio Shack, female to male jack, power supply from anything handy or spend $2 at thrift shop, $2 multimeter (Harbor Freight, Cheapo), junk variable resistor (pot).
7.4--8 V adjust. Or, get fixed value resistor dependent on PS voltage.
Charge anything,
And power supply for DVD house current.
Jomayan1@gmail.com
Sep 14, 2008 | Mintek MDP-5860 Portable DVD Player
Missing proview 758 power cord adapter
You should be able to get a cord from Radio Shack, Best Buy, Circuit City, Office Depot etc.
Sep 04, 2008 | Computers & Internet
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
locate the bottom of ur AP and read the following u should find these values:
Voltage: described by volts EX: 5 v or 12 v
Amperage: described by amperes EX: 500 ma , 1 A,....
Polarity: whre is minus and plus
write these values and u can buy any power supply or power adapter based on these values if not sccseeful write me ill help u more
wafik_eid@hotmail.com
Nov 21, 2007 | Arris WA840G 802.11g/b (49832000100)...
Missing external converter
Hi, the best solution for your problem is to go to the manufactueres website, check their sales page and locate a dealer near you. If as I suspect thee PSU is like most others you will be better off buying a new case with power supply. I have found the difference is only a matter of a few dollars. Regards mistyman
Aug 27, 2007 | Fantom Drives Power Supply
Sharper Image ICEflow Portable Air Conditioner Logo
64 people viewed this question
Top Sharper Image Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Sharper Image Heating and Cooling Expert? Answer questions, earn points and help others
