Question about Kenmore HE2 Plus Front Load Washer
Washer flashing F22 and dooris locked and will not open. How do you unlock the door to reove the clothes?
  • Kenmore Master
  • 8,220 Answers
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
Sample tech sheet for HE frontloada
Get your tech sheet by removing your bottom panel or posting your model number here
Duet manual and more here
Posted on Sep 10, 2010
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
My drivers side door will not open. It cannot be unlocked with the key, nor from the inside door lock. I have disconnected the battery to see if the locks could be over ridden and it did not change.When...
Inside the door is little rob which control the locks....on the rob inside the dooris a little plastic arm which holds the rod to the locking arm mechinism.it has broken
Oct 09, 2009 | 2003 Kia Optima
F22, washer is locked and will not unlock
IT is a defective lock, unplug the machine for 30 minutes and plug it back in. Then once the door opens replace the door lock and all should be well
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WFW9200SQA12 F22 code problem
The problem you are experiencing is a Long Drain error. You need to check the drain pump reservoir and drain lines for obstructions. the following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If cleaning the pump does not correct the problem, it is recommended by the manufacturer that you replace it. It does not take much to permanently damage these small pumps. If anything has been lodged in the intake if the pump for any significant period of time, the motor and/or impeller may become damaged. This results in a pump they "appears" to be running, but may not be pumping anything.
In addition, check the drain hose that runs from the bottom of the wash tub to the intake side of the drain pump. I have personally found small articles of clothing lodged in this area blocking the drain pump. Garments bags are highly recommended for small articles to prevent this.
I hope you find this information helpful. if you require additional assistance, please let me know.
Dec 16, 2008 | Whirlpool GHW9400 Front Load Washer
F 22 front door locked and door won't open.
hi there,
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
234 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
