Question about Gateway FPD1760 17" LCD Monitor
I want to put my laptop and connect it with Gateway monitor. What type of plugs do I need?
  • 11,361 Answers
Spec of the monitor http://www.dealtime.com/xPF-Gateway-Gateway-Monitor-FPD1760
It will need the VGA cable (3-row/15-pin D-SUB), you need to look at your laptop monitor port to see what you have for the output.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
And you will need to set the laptop video signal to be at the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Posted on Sep 10, 2010
SOURCE:
I am trying to connect to gate way monitor
You need a cable from the "audio-out" from your laptop to the "audio-in" port on the Gateway, to transmit the sound to the monitor.
Apr 21, 2015 | Dell Computers & Internet
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
Dual monitor for gateway mc7321u
FIRST YOU NEED ANOTHER VIDEO CARD TO PLUG YOUR SECOND MONITOR.WHEN YOU GET AND INSTALL THE NEW CARD POWER ON THE PC AND THE OS WILL DETECT IT.
Jun 05, 2012 | Gateway Computers & Internet
Mt6728 gateway laptop everything powers on but no display?
Plug the laptop into an external monitor and see if the screen comes up. If it does than you have either a connection issue with the LCD display of the monitor or an issue with the graphics card of the monitor. Either way you might have to open it up and "re-seat" the connection or check if there are any damaged wires.
Please rate if this helps
Mar 09, 2011 | Gateway MT6728 Notebook
I am trying to connect an old desktop to a laptop inorder to use it's monitor via a serial cable. It doesn't seem to recognize the desktop. What am I doing wrong?
First off two computers will no automatically "find" each other using using a serial cable
Why don't you just connect the old pc's monitor directly to the laptop? I am assuming your laptop monitor either stopped working or is too small for your liking. By plugging in the monitor you can use it right on the laptop.
another option is to use a crossover cable plugged into the network (ethernet ports) assign static ip address (suggest 192.168.0.1 & 192.168.0.2, mask of 255.255.255.0 on both and default gateway of 192.168.0.1) then use the remote desktop under accessories and use one to take over the other, just open the remote desktop, type in the ip address of the one you want to get to and boom you are working.
Let me know if you have any other questions
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 30, 2010 | Acer Aspire 5630 Notebook
My Gateway HD2201 turns on and off
change the resolution of vga to 1024x768
Mar 17, 2010 | Gateway HD2201 22" LCD Monitor
Gateway model m6307 screen won't turn on, the laptop turns on but not the screen
Remove the battery and then put it back after about 5 mins. Plug it into mains and see if that solves it. Sometimes when laptops "hang" like this-removing the battery solves it.
Jun 21, 2009 | Gateway M6307 Notebook
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
I need a driver for gateway 17 in. wide screen monitor FPD1775W
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Nov 19, 2008 | Gateway FPD1775W Monitor
Gateway 400sd4
You should try plugging in an external CRT or LCD monitor. Most laptops will automatically enable this port when you connect a monitor and reboot, but you may need to hit some combination of keys on the laptop if you don't see anything.
You should try this to see if the laptop is running properly other than the internal LCD or VGA hardware.
Dec 16, 2007 | Gateway 400SD4 Notebook
Gateway FPD1760 17" LCD Monitor Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
