Question about Canon Cameras
Canon Rebel - put in charged battery (have tried 3 different ones) and camera will not turn on.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
Canon rebel xti
Tr5y a factory reset on the camera. And try another Memory card.
Aug 19, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
No Power To Canon Digital Rebel XT
I believe this post will help you out..
Please CLICK HERE
May 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My canon rebel t3i won't turn on after I charged the batteries and this light kept turning on but now the camera won't even turn on .
First try a different battery in your camera.
second try your batteries in someone elses canon (same model)
third go to some one that can check the battery.
Has the camera got wet at all? if so then ther might be internal damage and need to be serviced
Jan 12, 2013 | Cameras
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
300D Digital Rebel is in truble err99
Try the following diagnosis steps: -
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Aug 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
