Question about Milwaukee Tool Case Heat Gun
Need torque head bolt setting on case w14 model a336bd
Toyota 80 series GLX auto landcruiser 1996 need head bolt torque a nd cam shaft torque settings
Torque setting Toyota Land-cruiser 80 Series 4.5 1995-98
Engine code: 1FZ-FE, 1HD.
Stage 1: 20 Nm (Start tightening bolts from center to outwards)
Stage 2: 39 Nm
Stage 3: Rotate each bolt by 90 Degrees.
Stage 4: Further rotate each bolt by 90 Degrees
Nov 22, 2014 | 1996 Toyota Land Cruiser
Head bolt torque yield
90% of head bolts are stretched when installed. If you have the torque settings, you can confirm this by checking the specs. If it says example, 90lbs feet, plus a quarter turn, this confirms they are gonna stretch once torqued.
In any case, yes, change those head bolts at all costs. DO NOT RE-USE THEM. Make sure to torque and in the order as well. do not use a random pattern when torqueing.
Nov 01, 2013 | 2002 Jeep Liberty
Need torque settings for cylinder head bolts on a 52 reg skoda fabia 1.4 16v any help much appreciated thanks
Torque settings for cylinder head bolts for Skoda Fabia 1.4 16v
Cylinder head bolts tightening order:
IMPORTANT NOTE: RENEW BOLTS!
Stage 1: Tightening torque = 30 Nm
Stage 1: Tightening torque = 90 Degrees
Please do rate my response. Thanks!
Dec 17, 2010 | Volkswagen Polo Cars & Trucks
NEED TORQUE SETTINGS FOR 18 HP MODEL 31H777-0297-E1. ROD BOLTS AND HEAD BOLTS. IS THERE A PATTERN TO TIGHTENING HEAD BOLDS
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Aug 16, 2010 | Briggs & Stratton Garden
I need torque settings for the engine ie head bolts v6 engine 1
i am replacing the heads on a GMC 350 cu in engine. what is the final torque of the head bolts?
Jul 15, 2010 | 1985 Chevrolet Camaro
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
Torque settings for cylinder head nissan sentra
Tighten in sequence to 29ft.lbs then tighten in sequence to 58ft lbs. then loosen all bolts. Then tighten in sequence to 33ft lbs. then tighten each bolt in sequence 90 degrees then tighten each bolt again 90 degrees
Jul 18, 2009 | 1999 Nissan Sentra
Milwaukee Tool Case Heat Gun Logo
215 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
