Question about Pride New Jazzy 600 Power Wheelchair by Mobility
The controller suddenly flashes idle mode...and something like must must complete whole cycle before using or something to that effect it disappeared from the screen before I could write it down
  • 692 Answers
Julie If the chair is new - less than a year old it is under warranty so contact the provider that sold you the chair to have them fix the problem. If Medicare purchased the chair you can contact a service company to have them repair the chair for you and they will bill Medicare. Contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 10, 2010
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
97 Jeep Grand Cherokee Laredo is knocking running real rough. Whole car shakes while idling. Wants to die at stop sign
If the knocking is caused by internal engine damage, that is a different issue.
If only rough idle, the basics say to check for leak of some kind, fuel--egr--vacuum, something of that nature.
How long since a tune-up? Are there any applicable trouble codes? You may be able to get some codes by cycling the ignition switch, on--off, on--off, on then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes. If that won't work, have to try something else.
Dec 03, 2015 | Jeep Cars & Trucks
Sony Cyber-Shot DSC-P73 Digital Camera suddenly flash is not working
The flash may be broken.
If not these are the flash settings on the camera in case a different flash mode has been set accidently.
Set the mode dial to [camera icon], and press [up arrow] on the control button repeatedly to select a flash mode.
The flash mode has the following features.
No indicator (Auto):
The camera decides to use the flash based on lighting
conditions. The flash will be used when
there is not enough light or when shooting a
subject against a light source.
(Forced flash):
The flash will be used regardless of the amount of ambient light.
(Slow synchro):
light. In this mode, the shutter speed is
slower under dark conditions, so you can
clearly shoot a background that is out of the flash-lit area.
(No flash):
The flash will not be used.
Oct 18, 2014 | Sony Cyber-Shot DSC-P73 Digital Camera
2006 Saturn vue, 4 cylinder. Ran out of gas, couple gallons put in, ran fine. Went to gas station filled up full. Driving home, noticed my reduced power indicator flashed a few times on then off. Once...
reduced power , electronic throttle control problem . Reduced Engine Power Mode
When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The ECM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
• Limited throttle mode--The ECM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
• Throttle default mode--The ECM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The ECM will perform the following actions:
- Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
- Ignore the accelerator pedal input.
• Engine shutdown mode--The ECM will disable fuel and de-energize the throttle actuator.
May 04, 2017 | 2006 Saturn Vue
Hello. I have a 2004 Monte Carlo SS. Just recently, I have experienced my car not starting. I have had ONSTAR do a Diagnostic test from my car, while I am in it, and it comes back fine. What happens is, I...
Read the following paragraph from GM, this will give you some insight on the passlock system on your vehicle.
The electrical switching portion of the ignition lock cylinder assembly is separate from the key and lock cylinder. The electrical switch portion and the key and lock cylinder synchronize and work in conjunction through the action of the mechanical assembly between the two components.
PASSLOCK(TM) SENSOR
The Passlock(TM) sensor contains 2 hall effect sensors. The tamper hall effect sensor is on the top. The security hall effect sensor is under the tamper hall effect sensor. Both of the hall effect sensors monitor the magnet of the lock cylinder through an opening. The tamper hall effect sensor is physically placed on top of the security hall effect sensor. This arrangement enables the tamper hall effect sensor to engage first if an intruder attempts to bypass the Passlock(TM) sensor by placing a large magnet around that area of the steering column. There is a tamper resistor inside the Passlock(TM) sensor in order to help prevent tamper to the system. Passlock(TM) equipped vehicles have a selection of 10 different security resistors ranging from 0.5K ohms up to 13.6K ohms . Installing one of the security resistors inside the Passlock(TM) sensor will generate a unique Passlock(TM) code. All 10 combinations of the Passlock(TM) sensor have the same part number.
BODY CONTROL MODULE
The body control module (BCM) contains the theft deterrent system logic. The BCM reads the Passlock(TM) data from the Passlock(TM) sensor. If the Passlock(TM) data is correct, the BCM will send a class 2 message to the PCM to enable the fuel injectors and crank relay.
During the tamper mode the vehicle may start. The vehicle will then stall. If the BCM receives the wrong Passlock(TM) data, the VTD system will immediately go into the tamper mode. The tamper mode will lock-out the vehicle fuel injectors and crank relay for 10 minutes . The SECURITY indicator will flash while the VTD is in the tamper mode.
If the Passlock(TM) sensor sends a correct password to the BCM when the ignition is in the ON position, the BCM will send a fuel enable and crank relay enable signal to the PCM.
SECURITY INDICATOR
The SECURITY indicator appears on the message center inside the instrument cluster. If the SECURITY indicator flashes or if the SECURITY indicator lights continuously during vehicle operation, refer to the system diagnosis.
POWERTRAIN CONTROL MODULE
The PCM communicates with the BCM over the Class 2 serial data line. When the BCM determines an incorrect password, it sends a Class 2 serial data password to the PCM in order to disable the crank relay and fuel injection system. If the BCM receives the expected voltage from the Passlock(TM) sensor, the BCM sends a class 2 serial data password to the PCM in order to enable the crank relay and fuel injection system. The PCM then allows the vehicle to start normally.
FUEL LOCKOUT CYCLE
The Passlock(TM) system has a lockout cycle of approximately 10 minutes . Once the vehicle is in the lockout cycle, the vehicle remains in the lockout cycle for 10 minutes , even if the ignition switch is turned from the ON position to the OFF position.
The Passlock(TM) system uses the lockout cycle in order to synchronize all of the Passlock(TM) components when any Passlock(TM) related part is replaced. The Passlock(TM) system requires 3 consecutive lockout cycles in order to complete the 30 minute learn procedure for a changed component.
CHANGING THE PASSLOCK(TM) COMPONENTS
The design of the Passlock(TM) system is to prevent theft even if the various theft deterrent parts change. The parts that can no longer be changed without the possibility of going into a tamper mode are:
* The Passlock(TM) sensor
* The BCM
* The PCM
If you replace any of these parts the vehicle may not start for 10 minutes . This is the long tamper mode. If this occurs, the system must go through a long tamper mode cycle. During this time the SECURITY indicator will be flashing for the full 10 minutes and DTC B3031 will be set. The BCM and the PCM require the full 10 minutes in order to complete a learn cycle. The ignition switch must remain in the ON position until the SECURITY indicator stops flashing. You will need to repeat the cycle if the ignition switch does not remain in the ON position. When replacing any of the above parts, perform the Programming Theft Deterrent System Components procedure.
The design of the Passlock(TM) system is to prevent the vehicle operation if the proper ignition key is not used in order to start the vehicle. The mechanical key, in normal operation, will turn the ignition lock cylinder. The Passlock(TM) sensor monitoring the position of the lock cylinder will relay the Passlock(TM) data to the body control module (BCM). The BCM will determine the validity of the Passlock(TM) data. The BCM will send a password to the powertrain control module (PCM). When the PCM receives the correct password the PCM allows the crank relay and fuel injectors to operate normally. The Passlock(TM) system requires the PCM and the BCM to communicate the various functions in order to operate. These functions transmit over the class 2 serial data line. For an explanation of the class 2 serial data description and operation refer to Data Link Communications Description and Operation in Data Link Communications.
Jul 19, 2011 | 2003 Chevrolet Monte Carlo
I have a 1992 Mercedes s500 which occasionally the rev counter suddenly jumps up & down then stops completely then ASR light comes on and the car goes into ''limp mode'', then after a few minutes it...
Suspect idle control motor, although mass air flow sensor problems have sometimes been related to idle surge. Have pcm codes pulled for further diagnosis.
Dec 25, 2009 | 1992 Mercedes-Benz Mercedes Benz S Class
CAN YOU TELL ME WHAT THE P1000 CODE MEANS FOR A 1999 FORD F-150 PICK UP TRUCK
P1000 means a drive cycle has not completed, it will only clear itself after driving the vehicle through certain driving conditions. If you try to clear the code, it will reappear until you repeat the drive cycle. I am not too familiar with what AE will show, but if you can access Mode 6 data or the OBD Drive Cycle(These are two options from the IDS at Ford), It may help to show what tests have either failed or not completed. Heres what must be done to clear the P1000:
Note: The IAT PID must be between 10-38°C (50-100° F) during the OBD II drive cycle to enter into all the OBD II monitors. The FLI PID must be between 15% and 85% at all times.
Drive in stop-and-go traffic with at lease 4 idle periods (30 seconds each) while observing the status of the OBD II monitor on the scan tool. If the exhaust gas recirculation (EGR), heated oxygen sensor (HO2S), evaporative emission (EVAP), secondary air (AIR) (if applicable) or catalyst efficiency monitor have not completed, drive on the highway at a constant speed over 64 km/hr (40 mph) not to exceed 104 km/hr (65 mph) for up to 15 minutes. Heavy accelerations, sudden decelerations and wide open throttles are not recommended. If the scan tool sends out a three pulse beep at any time, the OBD II drive cycle has completed.
If there is only one certain component that hasn't completed its test, there are individual driving conditions to help those tests pass or fail if something is wrong.
Jun 23, 2009 | Ford F-150 Cars & Trucks
Minolta dynax 5 camera, diplay has disappeared
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Apr 10, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Pride New Jazzy 600 Power Wheelchair by Mobility Logo
381 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
