Check you filter and screen .Check whether you need an replacement for them.
If you dishwasher has foam coming out from under the door, then the problem is that dish soap somehow ended up in the dishwasher or excessive rinse aid . It is not recommended to prewash the dishes before loading them into the dishwasher as only a small amount of dish soap can cause the sudsing that you experienced. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. Spilling rinse aid while filling the dispenser will cause sudsing also.
To clear the suds from the dishwasher sprinkle several tablespoons of non-dairy coffee creamer over the suds. The fat in the creamer will help break down the bubbles. Wait five minutes for the suds to lessen.
Many pump leaks happen around the seal on the pulley. Some pumps have a
weep hole that lets water drip out when this seal begins to go bad. The
solution is to rebuild or replace the pump.
You'll want to confirm that the fill hoses are connected and properly
tightened. Always use new rubber washers when re-installing the hoses.
Take care not to over-tighten the connection. Other leaks may be caused
by the drain hose being cracked, or by a leaky connection at the
water-inlet valve. Too many suds may cause the appearance of a leak when
actually it's just a sudsy overflow. Sometimes a drain hose leak occurs
at the end of the hose where it attaches to the washer. If the hose is
long enough you can cut the leaky end off and re-clamp the hose back on.
Usually though, when a hose begins to leak, it is best to just replace
the hose.
