My cable company gave me cable tv with a tivo. the box must connect to the TV via a 3 cord (red,white and yellow) wire the tv only has a coaxial plug.
    President:
  • 2,777 Answers
You need this device to fix your problem, it is an adapter that takes the red white and yellow connection, and outputs it via coaxial plug, so you can just tune to channel 3 or 4 on your TV and it will work fine! Here is a link to the item you need:
http://www.amazon.com/gp/product/B0014KKV7W?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B0014KKV7W
Posted on Sep 10, 2010
How do I find the right channel to set my tv on so it will receive cable tv
If it is a cable box and you are connecting via coaxial cable using the rf converter in the box it is usually channel 3-4 but it can often be switched. If it is a satellite box it may use a high channel number like 73. Keep in mind that there is a traditional tuner and a digital tuner in your tv set so you made need to connect the cable and then do a channel setup for it to sense the active channel.
The image quality is best when the cable box is connected in this order from poorest to best; coaxial cable, rca cables (red,white,yellow), s-video (on older televisions), component video and optical audio using the three yellow, blue, green cables for video and a white or red for audio or optical input, DVI, or the best, HDMI with support for 1080p and audio. On your TV you should use an HDMI cable and simply change the Input or source button to that. The HDMI cable integrates video and sound and it will transmit a dolby surround signal to your TV just as a separate optical connection will.
Nov 27, 2013 | Insignia 42" LCD Flat-Panel HDTV
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
TiVo installation
Since the Series2 doesn't do HD, you don't need any fancy connections, and it's pretty simple to hook up.
1) Disconnect the cable that's connecting your cable box to your TV, from the TV end.
2) Connect the end that *was* connected to your TV, to the "input" on the Tivo.
3) Get another piece of the same cable (coaxial cable), and connect the output of the Tivo to the input on your TV.
That's it.
You may just need to go to Best Buy and get a piece of coaxial cable to connect the Tivo to the TV.
If you need further help, let me know.
Dec 15, 2008 | Tivo Series2 Digital Video Recorder...
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
