Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
    Brigadier General:
  • 10,406 Answers
The only position that the ':' ("colon") can appear is immediately before the first '\'' ("slash") -- it's not allowed to have the ':' between the '\' and the 'Microsoft' strings.
Posted on Sep 10, 2010
Microsoft has stopped providing XP users with security updates, forcing them to either upgrade to another, newer operating system, or gamble with their safety. While the latest usage figures show that a large portion of users are moving away from XP, there's still a sizable number of users who aren't -- or can't.
If you're an XP user, or know some XP users, there's a trick which makes it possible to receive security updates for the aging OS for another five years -- right up until April 2019.
The workaround makes use of updates for Windows Embedded Industry (formerly known as Windows Embedded POSReady). This is based on Windows XP Service Pack 3, and the security updates which are being released for it are essentially the same ones Microsoft would have pushed out for XP, if it was still doing so.
You can't simply install the updates -- that would be too easy -- and you'll receive a version mismatch error if you try. But a simple registry tweak is enough to fix that.
Create a text document, and call it XP.reg. You'll need to make sure .reg is the proper extension -- so not "XP.reg.txt". If it's not showing up as a registry file, open any folder, go to Tools > Folder Options, select View and uncheck 'Show hidden files and folders'. That should fix the problem.
Right-click the file, and select Edit. Paste in the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
Apr 04, 2013 | Acer Computers & Internet
please anyone help us to how to resolve this . This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
Apr 04, 2013 | Microsoft Windows XP Professional With...
So how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
Fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Every time I start my laptop there is always appear two massage form and this is the problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows...
Hope you had deleted some files that relate to your system files.
Try to repair your system by Inserting your Windows XP Service Pack2. in your CD/DVD ROM and boot it again.
And if it's not working than you must format your system. And installed it. Here are the procedure to repair/install for reference. Thanks for Using FixYa All the Best!
Jul 28, 2011 | Microsoft Windows XP Professional With...
Windows script host settings
first try windows update
if that don't work right down exactly what script it is then
click start then run type in msconfig
then a box will appear click on startup
then find the program click to remove restart computer then click don't show message again
Jan 16, 2009 | Computers & Internet
Windows me
Download & install the Microsoft scripting engine(s) to see if that corrects the problem. You can get it here:
http://download.microsoft.com/download/winscript56/Install/5.6/W9XNT4Me/EN-US/scr56en.exe
May 09, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
791 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
