We have a ge front end washer.it will fill up anddrain but will not spin or agitate.it made a grinding noise the other night before it quit.
  • Washing Mach... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 10, 2010
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
