Question about ViewSonic Computers & Internet
The on/off button doesn't work on my viewsonic tv. I use the remote and it takes about 3 to 4 minutes of holding it before the green light eventually holds and turns on. What can I do?
  • 732 Answers
Kevin nathan, The ONLY THING you really need to fix is inside the monitor!!! And it ain't the switch!!! You or an electronics technician will most likely need to investigate the units "switch-mode-power-supply/CCFL inverter board for swollen, leaking, electrolytic filter capacitors and/or poor quality frosty looking component to printed circuit board soldering that has over the years become "thermal-cycle-fractured" and are now intermittantly open circuited. Let us know what you intend to do about your intermittantly "blacknblank" unit, or if you need more assistance or where to find more info. 12fixlouie
Posted on Sep 10, 2010
My viewsonic n2751w tv will not stop channeling down... have to put weight on top to stop
mmm sounds like a sticky channel switch on your tv itself. Spray some special stuff called Contact cleaner spray available at any electrical outlet or hobbyshop - its a little bit expensive but works great to clean motherboards and most other electrical equipment. Spray while the tv is off and press buttons in between sprays
Jan 14, 2015 | ViewSonic N2751W 27 in. LCD Television
My 4.4 dish network remote codes listed for viewsonic hdtv do not work,I have tried:507,551,562,566,575,583,600,752,760,796 ( 606would not program into remote)
Hi there TonyMichael, my name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you and provide you with information that can help program your remote to your television. The codes we have listed for a Viewsonic Tv to be programmed with a 4.4 IR/UHF Pro remote are: 566, 505, and 760.
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at kimberly.escobar@dish.com!
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Oct 11, 2013 | ViewSonic N2630w 26 in. LCD TV
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
TV (#N3760W) won't turn on (immediately).
sounds like the board connecting to the power switch going bad. are you using remote?
Oct 17, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic model vs10846-1m aka N4060W won't turn on.
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Jan 28, 2009 | Televison & Video
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Computers & Internet Logo
664 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
