Question about Amana ARGS7650SS Gas Kitchen Range
I keep getting a F4 code and oven won't work - Amana ARGS7650SS Gas Kitchen Range
  • Amana Master
  • 3,051 Answers
HELLO THERE
this f4 code can also be a f3 but they all mean the same thing ity is telling you that the temperature sensor is bad and needs to be replaced
This is normally about a 30 to 40 dollar part it should be available at a local appliance repair center
Posted on Sep 27, 2010
At work we have molder ge drop in stoves and we are getting error codes f3 f4, then oven turns off
f3 and f4 are temperature sensor faults. check the thermometer sensor in the oven.
Dec 14, 2014 | GE Kitchen Ranges
F4 Code
Could be a result of:
contamination on terminals
pinched wire in oven temperature sensor circuit
cold solder joint on control.
Dec 05, 2012 | Kitchen Ranges
The oven keeps beeping code F4.
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Amana AOCS3040 Electric Single Oven
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
F4 code Dacor oven
F4 means there is an open circuit in the Oven Temperature Sensor. Could be a bad sensor that needs replacing, cound be an issue with the wiring harness.
A test would be to short the sensor wire together at the sensor. the error code should change to F3. then you would know it is the sensor and not the harness.
Mar 03, 2010 | Ovens
It keeps saying f4
Hi, check the code description below.
F4 Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
Oven comes on then beeps and a code F4 comes on
how do I solve a F4 problem in the Decor electric stove?
Feb 02, 2009 | Ovens
Jen Air jjw9530bab F4 code
HI thanks for your question. the code F 4 means an open temp sensor. which is located in the oven , top left corner. replace the oven sensor. thanks the appliance doc. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air JJW8530C Expressions Collection...
Amana ARGS7650SS Gas Kitchen Range Logo
250 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
