Question about Whirlpool Duet GHW9150P Front Load Washer
We were getting an FH flashing code. My wife unplugged it. The hot and cold water had not be turned back on after remodeling. We have plugged it back in and all we get is a humming noise and the time flashing. Help!
    President:
  • 1,932 Answers
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
  • Check CCU operation
Thank You
Posted on Sep 10, 2010
I have code fh
Hey Lukec,
The FH error code on your Kenmore Elite washer indicats that there is a problem with in-coming water flow. When the water feeding the washer is less than what it should be, the FH code will trigger and the washer will shut down.
You can check a couple of common problems that can manifest this error code after resetting the machine. Steps for reset and diagnostics can be found below.
  1. Using the "Pause/Cancel" button on the washer control panel (this button will be below the digital time clock, to the lower right of the wash cycle selector) by pressing the "Pause/Cancel" button twice to cancel the wash cycle.
  2. Next, unplug the washer from the wall socket (this will reset the error code).
  3. Several things you can do to troubleshoot the follow issue are these:
    Check for kinks in the water supply hose.
    Turn off the water supply (hot and cold) and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  4. Reconnect the water supply hoses to the washer and turn on the water supply.
  5. Plug the washer cord back into the wall outlet.Select the wash cycle and press the "Start" button.
If the error code returns, you will likely have internal water flow issues due to the pump or other internal problems which may require a service technician.
Hope this helps.
Oct 03, 2014 | Kenmore Washing Machines
Whirlpool awm 8103/s keeps stopping during cycle with code FH displayed? any suggestions
Whirlpool's 'FH' stands for 'no water inlet' (but goodness knows how 'FH' could mean that!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 04, 2011 | Washing Machines
I have a whirlpool duet front load washer. when I put a load in on normal cycle, at some point it was flashing an H and an F on the display. Tried to pause it and unlock the door, but nothing happened....
Whirlpool's 'FH' decodes as 'no water inlet'- I suspect 'Hot Fault'!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jun 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing maching flashes F H on time display
Hi
The FH code indicates a fill failure. The problem can be with the fill valves, flow meter or the pressure switch. This error occurs if the control doesn't see the flow meter turning. This usually a fault of the flow meter but be sure both the hot and cold water valves are working. Try a hot water wash cycle and confirm that hot water is coming into the washer. Check both valves and if they are working the problem is most likely the flow meter.
Also the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Please get back to us if you have further query else please accept the suggestion.
Mar 02, 2011 | Maytag MAH6700A Neptune High Efficiency...
My whirlpool washer stops and the water tap closed light comes on, plus on the time remaining FH comes on
the hot water tap has to be on aswell because it picks up the outside temperature and if its too cold it will ask for a squirt of hot water because the water has to be at a certain temp to react with the detergents properly just this model that does it
Jan 05, 2011 | Washing Machines
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
