Question about Sony Handycam DCR-TRV530 Digital Camcorder
C:32:30 The compartment where the 8mm tape goes is not opening. (and there is a tape in the camcorder).
    Genius:
  • 1,812 Answers
The error code C:32:20 is a take-up reel malfunction. The ejection malfunction is something else and can be caused by several problems including a defective eject switch in the cameras internal circuitry and can usually vbe repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 10, 2010
CAMCORDER'S TAPE IS STUCK, WHEN I PRESS EJECT, THE OUTER COMPARTMENT OPENED BUT THE TAPE COMPARTMENT DID NOT. IT WILL NOT GO DOWN ALSO?
You might have a sony handycam? If so, it is a manufacturers problem that came with the camera. Mine does this all the time, just slap the outside of it and it works. I know it sounds harsh - only do this if you have a sony handycam.
Sep 25, 2009 | Sony 8mm Stantard Grade 120 Minute...
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Jun 12, 2009 | Sony Handycam CCD-TR87 Camcorder
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-TRV145E Digital 8 camcorder - won't play or record.
Fortunately they are still making 8mm camcorders usually running less the $200 to replace. It could be more cost effective to get a new model for that price as well. I couldn't record on my Sony 8mm camcorder anymore after five years of use and over 100 tapes that I had recorded. It's plays back but that's about it.
Aug 19, 2008 | Sony DCR-TRV285E Digital-8 Digital...
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no...
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Jul 24, 2008 | Cameras
8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Jun 10, 2008 | Video Cameras
8mm tape got stucked in an hitachi camcorder
TAPE IS JAMED NEED TO TAKE IT APART A REMOVED MANUALLY
May 20, 2008 | Sony 8mm Stantard Grade 120 Minute...
Tape stuck in camcorder
Turn off
Take battery out
plug in to power
turn on
Tape shoudl pop out.
it worked for me!
Jul 31, 2007 | Sony 8mm Stantard Grade 120 Minute...
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Jan 21, 2007 | RCA PRO854 8mm Analog Camcorder
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam DCR-TRV530 Digital Camcorder Logo
149 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
