Question about GE Energy Star WCVH6260F Front Load Washer
Brown and gray spots on white clothes.Clean the machine with bleach and magic wash and spots still occur.The washer drum was replaced,gray spots still occur.
  • 101 Answers
Get who did it back,not something you can fix
Posted on Sep 10, 2010
Kenmore calypso washer bleach
I would take the bleach hose off and verify it is not obstructed, if that doesn't look bad then the system that calls for bleach my be faulty, but I would check for obstructions first in the hose first.
Jan 15, 2014 | Whirlpool Washing Machines
I am getting little brown spots on my white clothing. Bleach seems to take them out. It just started happening.
sounds like a rear drum shaft seal may be leaking and getting either rust or brown grease spots on your clothes.If this the case,you should be able to see signs of water leakagein the back of the unit.Take the rear cover off and look in the area behind the large drum pulley.This problem also usually results in noisy operation eventually.The water would be getting into the tub bearing behind the seal.
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Oct 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
White spots on clothes
YOUR PROBLEM IS ONE OF TWO THINGS.FIRSTLY DEPENDIN HOW OLD THE MACHINE IS THERE COULD BE A BUILD UP OF LIME SCALE AROUND THE DRUM.TO SOLVE THAT YOU NEED TO PROGRAM YOUR MACHINE ON A HOT WASH AND LET IT RUN EMPTY TILL THE END OF THE CYCLE.SECONDLY YOUR SOAP POWDER MIGHT NOT BE DESOLVING PROPERLY.YOU MIGHT NEED TO DISSOLVE IT AND MAKE IT LIKE A WATER PASTE BEFORE INSERTING IT INTO THE MACHINE.GOOD LUCK.MOHAMED
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Our washing keeps getting bleached spots / areas. Clothing has light patches.
it wont be the machinei think.
try doing a hot wash cyle on an empty machine with some descaler powder or soda crystals to clean it out.
Aug 25, 2008 | Hotpoint WMA58 Front Load Washer
Whirlpool duet front loader washer/dryer
It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
358 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
