Question about Janome 6019QC Mechanical Sewing Machine
Every few stitches the thread catches - Janome 6019QC Mechanical Sewing Machine
  • 161 Answers
Try cleaning everything, and check that you have the needle in properly and all the way in. perhap the bobbin has a bur? hope this helps
Posted on Sep 13, 2010
I have a singer 6268 a few days ago fabric jammed underneath the plate and it threw off the timing. I just adjusted the timing but now it won't stitch the needle works fine but won't catch bottom thread to...
It's a very risky thing for an unprofessional to adjust timing. Very tricky. Is your needle new and unbent? If everything is rethreaded correctly etc and it still won't work then you will just have to take it
for a refit.
Jan 01, 2015 | Sewing Machines
Why won't the stitches catch when machine quilting?
It may be a tension or a threading problem. There are videos on youtube that may help. Change wording on youtube search to find issues that match your problems. Follow link.
sewing machine problems YouTube
Jul 30, 2014 | PfaFF Tiptronic 2040
My singer 4830C sewing machine won't make stitches. It runs the thread across the fabric but isn't catching
Clean the bottom. The place that nail going into it. You can use Vaccume too.
Dec 15, 2013 | Singer 4830
Husqvarna emerald bobbin cuts
When you turn the handwheel, is the needle centered in the hole in the plate or is it just barely clearing?
Feb 18, 2013 | Husqvarna Sewing Machines
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
Embroidery machine not pulling top thread on 385.19000
White on top means that the top tension isn't right some how. Now that can be because it wasn't threaded properly with the foot in the up position... or it could mean that you've got the little thread catcher **** on your spool catching the thread and causing problems. Sometimes if it catches it will wind a few layers of thread around the thread spindle the spools sits on. That isn't readily notice until you get mad and pull the spool off.... and finally see it. LOL
Carefully examine the path of the upper thread too.
Good luck.
Aug 19, 2012 | Kenmore 19001
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Aug 30, 2010 | Janome 1017 Mechanical Sewing Machine
Asinger model 5050 will not make stitches,checked all points,
your machine sound like it is out of time you need to take it to a service center
Jan 15, 2009 | Singer 5050 Mechanical Sewing Machine
Machine jams after a few stitches
Take a few stitches and look for where the thread is hanging as the loop slides over the bobbin case. If there is a rough spot causing it to hang, smooth it out with very fine steel wool make certain to remove all remains of the steel wool when you are finished. If the thread is catching between the bobbin case and some other surface, the clearance between the surfaces needs to be set and you should take it to a qualified repairman.
Apr 21, 2007 | Singer 8280 Mechanical Sewing Machine
Janome 6019QC Mechanical Sewing Machine Logo
21 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
