Question about Pioneer DEH-P8400MP CD Player
Hi, would appreciate if someone can email me a picture of the harness/connector assembly. i accidentally pulled of 4 wires and cant figure out which goes to what slot. the power, ground, acc (red cable), and yellow wired was pulled from the set. thanks in advance
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
  • 6 Answers
SOURCE: i cant get power is my harness missing wires?
Yes, your red wire is for ignition, yellow wire is for battery and black is ground. The red ignition wire is for the radio to turn off and on with the ignition. The yellow is always hot, for memory.
Posted on Dec 29, 2008
nuwan chinth
  • 111 Answers
SOURCE: dehp5800mp wire harness
orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
Posted on Jan 06, 2009
bunnydawg
  • 5158 Answers
SOURCE: memory not working
blue yellow to yellow and gray to red should be right
Posted on Feb 01, 2009
Have my steering column on 2001 Jeep Cherokee sport opened up to replace hazard/turn signal flasher block. Cant find its location. Have already changed out turn signal switch assembly.
On the switch you just replaced, trace the RED/WHT and VIO/TAN wires toward the front of your Sport and they will connect to the combination flasher. It has BLK and BLK/PNK wires connected to it.
Sep 11, 2016 | Jeep Cherokee Cars & Trucks
Remove left front door (ds)
The connector is inside the door jam/body. Use a screwdriver to pull the rubber boot off. either you will see the plastic the unlatch the connector or you will have to pull the connector out of the body to disconnect. Most are pull the wires and connector out.
Feb 05, 2016 | Hyundai Sonata Cars & Trucks
How do i remove rear turn signals on 2009 street bob?
If you need to remove the tail lite, brake lite and signal light harness start by removing the seat. Then disconnect the negative battery cable. Then detach the rear electrical harness connector. Then locate and follow the wires for the taillight and signal lights to the connector (8 pin) under the seat area and separate the connector. Then cut the cable tie strap holding the wiring harness to the frame and pull the harness through the fender opening. Then follow the conduit/harness back to the fender hole where the wiring exits the fender underside and enters the tail lite housing and backplate. This is not necessary for removal of the tail/brake lite assembly or the signal lie assemblies.
If you want to remove the tail/brake lite assembly remove the tail light lens and the with a small screwdriver depress the small tang in the tail lite four wire Multilock connector and remove the tail lite and then do the same and release the two wire signal light connectors one at a time from the tail lite base and remove the signal light connectors. These smaller two wire Multilock connectors are on the left and right sides of the base plate in the centre portions of the base plate where the 4 wire tail lite connector on the left side of the base plate is located and the wiring harness connector of the wires from the front of the bike to the base plate on the right side. The wires from the left and right signal lite assemblies go from these connection points on the base plate out through each side of the base plate and into the area under the back of the rear fender to each signal lite assembly. Then similarly release the Multilock connector of the harness from under the seat to the tail lite base. When you have disconnected the connectors from the base plate and have routed the wire harnesses out into the area under the fender you can release them from the wire clips at each side of the under fender areas. Then for each side remove the lamp support by unscrewing and removing the fastener and washer inside the rear fender, after which the lamp housing can be removed from the lamp support by pulling it and the wiring you disconnected from the tail lite base out through the lamp support. If you wish to release/remove the tail lite base undo the fastener and remove it.
Jun 03, 2014 | 2006 Harley Davidson FXDBI Street Bob
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
Error code le on washing machine wm-1480fhd.... drum stops spining in certain directions and then stops with the error code :LE
Well, according to the LG error look up table:
LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Decoding the techno speak, this means that the little rev counter, built on to the back of the motor and connected by 3 wires has either come loose, fallen off, failed or its wires are unplugged. The result is the machine can't figure what speed the motor is running at, so it shuts it down.
Sep 16, 2011 | LG WM-1480FHD Front Load Washer
How to change multifunction switch on 04 buick century
STEP BY STEP INSTRUCTION First, any time you work around the steeringcolumn you it is a must to disable the air bag system you will do this my disconnectingthe battery. After you disconnect the battery wait at least 5 minutes before proceeding. 1. Ifyou have tilt remove the tilt actuator arm by firmly pulling straight out. 2. Removethe upper and lower trim covers. 3. Removethe wire harness assembly from the wire harness strap. 4. Disconnect the turn signal andmultifunction switch assembly connector from the SIR system coil connector.This is alongside the steering column there is an 8mm bolt in the center of theconnector that must be removed to disconnect the connector halves. 5. Slide the 2 connectors of the turnsignal and multifunction switch assembly out of the bulkhead connector. With a smallscrewdriver slightly pry between the connectors to release them. 6. Removethe 2 pan head tapping screws and from the turn signal and multifunction switchassembly. 7. Removethe turn signal and multifunction switch assembly from the steering column tilthead assembly. INSTALLATION PROCEDURE 1. Installthe turn signal and multifunction switch assembly onto the steering column tilthead assembly. 2. Screwthe 2 pan head tapping screws and into the turn signal and multifunctionassembly.3. Slidethe 2 connectors of the turn signal and multifunction switch assembly into thebulkhead connector. 4. Connectthe turn signal and multifunction switch assembly connector to the SIR coilconnector. 5. Installthe wire harness assembly (1) into the wire harness strap (2). 6. Installthe upper and lower trim covers. 7. Installtilt actuator arm. 8. Reconnectthe battery.
Mar 01, 2011 | Buick Century Cars & Trucks
How do you remove the dash in a 1995 ford f-250
1992-96 Vehicles
Fig. : Instrument panel installation-1992-96 vehicles
CAUTION On vehicles equipped with air bags, please refer to Chassis Electrical for arming, disarming and precautions. Accidental deployment of the air bag system can cause serious personal injury.
  1. Disconnect the negative battery cable.
  2. Unplug the connectors from the instrument panel rear lamp wiring and the engine control sensor wiring in the engine compartment by loosening the bolts and separating the connectors.
  3. Remove the radio as outlined
  4. Remove the right and left side windshield side garnish moldings.
  5. Remove the 4 screws attaching the top of the instrument panel to the cowl.
  6. Remove the 2 screws attaching the instrument panel steering column opening cover assembly to the underside of the instrument panel.
  7. Remove the cover by pulling up at the top of the cover and unsnapping the 4 retaining clips.
  8. Pull the antenna lead-in cable down and unsnap the wire from the bottom of the instrument panel and lay the wire down on the floor out of the way.
  9. Remove the bolt attaching the instrument panel to the panel brace. Some vehicles may have 2 lower braces.
  10. Remove the screw and washer assembly located at the lower corner on the right side of the instrument panel.
  11. Unplug the wiring connectors from the main wiring harness at the right cowl side panel.
  12. Unplug the wiring connector from the parking brake control.
  13. Remove the 3 nuts attaching the parking brake control to the left side cowl panel and lay on the floor. Do not disconnect the parking brake cable.
  14. On vehicles with column shift; disconnect the shift cable from the steering column shift cable bracket.
  15. Unplug the wiring connector from the brake light switch.
  16. On vehicles with manual transmission; unplug the wiring connector from the clutch interlock switch.
  17. Unplug the wiring connectors from the main wiring harness at the left cowl side panel.
  18. Remove the pinch bolt from the steering column to the lower steering column shaft. Move the lower steering column shaft toward the engine and separate from the column U-joint.
  19. With the aid of an assistant, support the instrument panel and remove the 3 bolts and 1 nut attaching the left side of the instrument panel.
  20. With the aid of an assistant, pull the instrument panel rearward and disconnect the heater controls and air conditioner vacuum line connector, if equipped. Unplug any remaining wiring harnesses.
  21. With the aid of an assistant, carefully remove the instrument panel through the front door.
To install:
  1. With the aid of an assistant, carefully position the instrument panel through the front door.
  2. With the aid of an assistant, position the instrument panel forward and connect the heater controls and air conditioner vacuum line connector, if equipped. Engage any wiring harnesses
  3. With the aid of an assistant to support the instrument panel, install the 3 bolts and 1 nut attaching the left side of the instrument panel.
  4. Move the lower steering column shaft toward the column U-joint and install the the steering column pinch bolt to the lower steering column shaft. Tighten to 30-42 ft. lbs. 41-57 Nm).
  5. Engage the wiring connectors to the main wiring harness at the left cowl side panel.
  6. On vehicles with manual transmission; engage the wiring connector to the clutch interlock switch.
  7. Engage the wiring connector to the brake light switch.
  8. On vehicles with column shift; connect the shift cable to the steering column shift cable bracket.
  9. Install the 3 nuts attaching the parking brake control to the left side cowl panel.
  10. Engage the wiring connector to the parking brake control.
  11. Engage the wiring connectors to the main wiring harness at the right cowl side panel.
  12. Install the screw and washer assembly located at the lower corner on the right side of the instrument panel.
  13. Install the bolt attaching the instrument panel to the panel brace. Some vehicles may have 2 lower braces.
  14. Position the antenna lead-in cable up and snap the wire to the bottom of the instrument panel.
  15. Install the 2 screws attaching the instrument panel steering column opening cover assembly to the underside of the instrument panel.
  16. Install the top of the instrument panel to the cowl with the 4 retaining screws.
  17. Install the right and left side windshield side garnish moldings.
  18. Install the radio as outlined
  19. Install the connectors to the instrument panel rear lamp wiring and the engine control sensor wiring in the engine compartment by engaging the connectors and tightening the retaining bolts.
  20. Connect the negative battery cable and arm the air bag system
Hope helps (remember rated this).
Jul 14, 2010 | 1995 Ford F250
Steering wheel covers
I hope this helps....these are the steps to removing and replacing the cylinder:
  1. Remove the knee bolster.
  2. Remove the steering column trim covers from the steering column.
  3. Disconnect the steering column electrical connectors.
  4. Remove the wire harness assembly from the steering column and the wire harness strap.
  5. Slide the 2 connectors of the turn signal and multifunction switch assembly out of the bulkhead connector.
  6. Remove the key alarm connector from the lock module assembly in the following way:
  7. Rotate the key alarm connector 90 degrees.
  8. Pull the key alarm connector out of the lock module assembly.
  9. Remove the passkey connector from the lock module assembly.
  10. Remove the connector from the electric park lock, for vehicles equipped with floor shifters.
  11. Remove the ignition switch from the lock module using tool J42759 or equivalent.
To install:
  1. Install the ignition switch to the lock module
  2. Install the key alarm connector into the lock module assembly.
  3. Push the key alarm connector into the lock module assembly.
  4. Rotate the key alarm connector 90 degrees so that the key alarm connector locks into place.
  5. Install the passkey connector into the lock module assembly.
  6. Install the connector to the electric park lock, for vehicles equipped with floor shifters.
  7. Slide the 2 connectors of the turn signal and multifunction switch into the bulkhead connector.
  8. Attach the wire harness assembly to the steering column wire harness strap.
  9. Connect the steering column electrical connectors to the vehicle.
  10. Install the trim covers to the column.
  11. Install the knee bolster.
  12. Enable the SIR system.
  13. It may be necessary to reprogram the theft deterrent system if the module was replaced.
Mar 06, 2010 | 2001 Chevrolet Suburban
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
Pioneer DEH-P8400MP CD Player Logo
22 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
