Question about GE WSXH208A Front Load Washer
We have a washing machine leaving dirt on the laundry. why?
  • 101 Answers
Is it a he detergent machine .check your detergent
Posted on Sep 10, 2010
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Tip
How to clean a wash machine
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas.
Finally, run the machine through a complete wash cycle before you put any more laundry in.
on Jan 16, 2010 | Washing Machines
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
Where is the dirt trap on the Hotpoint WMD 740?
Run the washing machine with a cleaner compound like http://www.target.com/p/tide-high-efficiency-washing-machine-cleaner-5-count/-/A-14230069
Also the pump can be cleaned by undoing the tap at the bottom front of the washer. First make sure the drain tube has been pulled out to empty residual water in a container. Then unscrew the tap and filter to clear any dirt and items stuck in it.
Check the manual at this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMD740PUKRE_19509388200.pdf
Sep 16, 2014 | Hotpoint Washing Machines
My Whirlpool duet washing machine is collecting water in the tub after laundry is long done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Kind of the opposite of these tips... your fill solenoid has dirt in it and it won't shut off...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Black marks
To eliminate possible bearing failure, spin the drum by hand and see if u can detect any rumbling noise or strange nioses coming from the drum, if u can then it is probably grease that is coming from the bearings. The other possible cause is an effect called ****, this is a result of washing at too low a temp, this causes a build up of dirt and grease,leading to the sort of prob that u are experiencing The thing u should do is to put the washer on at a high temp with powder in but no washing and do a full wash . This is called a maintenance wash, and should be done at least three or times a year depending on how often u wash more frequently if u do a lot of washing. Clean the door glass and rubber seal as thoroughly as u can ,and remove as much sludge and dirt as poss. This should help with your prob. Plz rate my solution. Thanks.
Dec 31, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
GE WSXH208A Front Load Washer Logo
32 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
