Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitusbishi medallion hdtv 1080 integrated a green light blinks off and on then it goes off, then comes back on and doenst stop blinking, we try puting the tv on and it will go on but then will go off and light will stay blinking
SOURCE: have a mitsubishi hdtv 1080
no i havent fixed it. i couldnt get help from your so called experts because i dont have a credit card to pay you so i will keep trying to get help from someone whos really willing to help .
Posted on Dec 02, 2008
SOURCE: mitsubishi 65 medallion hdtv 1080
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
this has how to fix the blinking light check out this forum for more on this type of stuff
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/108250
Posted on Dec 28, 2008
freetek
  • 5568 Answers
SOURCE: green timer light blinking tv won't turn on
My thanks to your husband (and all who are involved in this stupid conflict) for his service.
You didn't mention whether there was a pattern to the blinking which in some sets can be decoded  into a specific problem. I'll assume it is a regular blink rate you have.
All modern sets have a standby state that allows them to respond to the remote when they are 'off.'  The power for the LED that's blinking comes from this 'always on' power supply and the fact that it is blinking probably (and unfortunately) means that either the main power supply has failed or possibly the lamp in some brands.
Because this can come from more than one place, it's not possible to determine which source it might be.  The owner's manual might give info under 'Troubleshooting' as to the source.
If you don't have the manual available, you can download one here:
Mitsubishi Manual
If you find that it is the main power supply, this is likely on a separate board and may be user replaceable.
Pull the AC plug from the wall and let it sit for at least a couple of hours to allow certain components to loose any dangerous charge. Remove the lower panel from the set and look for a board with larger than average parts on it, particularly cylindrical objects (capacitors) and larger dark blocks (transformers). Look on that board for a part number for the board (not the components).
Locate the nearest Mitsubishi repair company and call to see if they repair failed boards or only sell new. Once you have the price for it (could be $90-$200 US), you can decide if you want to replace or repair it.
Replacing the board is probably not rocket science and have had several ladies do this on their own.
If you find it is the lamp that has failed, this is also something you can do without great technical skills and the prices for these ranges from ~$125 - $200.
Posted on Apr 29, 2009
SOURCE: mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
Posted on May 04, 2009
ladywinn
  • 5138 Answers
SOURCE: my 65 in mitsubishi medallion hdtv 1080 wont turn
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Posted on Nov 18, 2009
Testimonial: "excellent knowledge and communication! "
My 65 in mitsubishi medallion hdtv 1080 wont turn
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Older medallion 55" 1080...switched itself
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65 medallion hdtv 1080
Aug 27, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi hd 1080 medallion
May 30, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
298 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
