Question about Vertex FNB-27SM, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 1500mAh NiMH 2-Way Radio
YAESU FT-530 won't power on with the battery but works fine with an external power supply. The battery is new and works on my other ft-530. Thanks for any help you can give.
  • Gary Smith Apr 18, 2013
    My FT-530 won't power on at all either on external or battery. The lamp works and APO is displayed but won't turn on.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Yaesu Ft-60R with Kenwood TK-3107
Initially and the simplest probably would be to use the units without enabling the CTCSS or any form of encoding (turn this feature OFF). In the meantime, will check the specs and post if anything concrete comes up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
SOURCE: Operating The Yaesu FT-767 GX
hello this borja from spain.
i have all manuals of this radio even the schematics
email me and i,ll send you back all info caramelovetense@hotmail.com
Posted on Dec 27, 2008
SOURCE: Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Posted on Apr 07, 2009
  • 11 Answers
SOURCE: I need to replace the internal lithium battery on
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
Posted on Jul 11, 2009
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
Hello! I've a couple of battery packs yaesu FNB27. The old NiCad batteries do not work. I want to replaced it by new LiH type. What is the best way to open the battery case without damaging it? thanks...
It's difficult to open the Vertex packs without ruining them. FNB27 is widely available on eBay or you can get them from manufacturers such as W&W in Hicksville NY online. I don't know if anyone has made them in Lithium Ion yet.
Mar 13, 2011 | Vertex FNB-27,...
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I need to replace the internal lithium battery on a yaesu FT-416 - how do I do this?
Jun 17, 2009 | Vertex FNB-26,...
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Feb 24, 2009 | Vertex FNB-27SM,...
Yaesu ft-815
Double check that "TSQ" is not enabled. In the menus you can fine "SQL" and select the type of squelch. If you have "TSQ" selected you'll only hear signals from radios that a re transmitting the CTCSS tone selected.
Jan 21, 2009 | Vertex FNB-27SM,...
Powering the Yaesu FT-11R
The battery select determines whether you're using a NiCd or Alkaline battery, I believe the "adjust" is used to put the radio into service mode. If there's not an "auxiliary power input" you can hook up the bench supply to, check the battery output for the voltages and polarities, and hook up your supply accordingly.
Dec 07, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Radio Communications Logo
426 people viewed this question
Top Vertex Radio Communications Experts
eradiostore
eradiostore
k24674
scott265
Level 1 Expert
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
