Question about Frigidaire GLTF2940ES Front Load Washer
I have an ltf2140es0 it will not come on the cancel will not respond and it will not start. i have cycled power with the same result
  • samiddlebroo Sep 10, 2010
    all lights except door lock plastic door key insert is intact
    machine is beeping as well when i hit start and cancel i can adjust the load select and different spin light comes on as it always does. i wonder about door micro switch but it should respond to cancel button whether switch is made or not??
  • Frigidaire Master
  • 19,396 Answers
THe washer is in fault mode.
To pull codes hold down both the Pause/Cancel and OPTION buttons at the same time. It will return an error code that you can report here.
Start also tripping circuit breaker, checking drain hose and ensuring door is well closed. Further maintenance will be probably required.
Posted on Sep 10, 2010
  • 5,081 Answers
What are the lights blinking when you try to turn it ON?
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
Frigidaire LTF2140ES0 washer lights come on but doesn't start
Hello friend, thanks for your post!
If your Frigidaire washer, LTF2140ES0, is not starting it could be a possible issue with your control panel or door latch. Is your washer showing you any error codes? Double-check to ensure that the door is closed. If it is secure, reset the power to your washer for roughly ten minutes. You can do this by either unplugging it or flipping your circuit breaker into the off position. If the issue continues, it could either be the door lock assembly or a communication problem with the control board. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. I hope these troubleshooting tips help you in some small way. -Matt
Sep 25, 2014 | Washing Machines
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
After power fluctuation machine does not start only beeps
Push and hold stop / cancel for 8 seconds and then try and set the cycle. Usually after a power fluxuation there is a PF displayed. If this does not get you started please respond with a model number please so I can use the service manual for your machine.
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 26, 2010 | Fisher and Paykel Washing Machines
How do I Cancel a wash cycle? I have no manual
The Reset button is the correct button to cancel the cycle, it takes up to a minute or so the drain. If the buttons are not responding, there could be a problem with the door closed switches.
Jun 08, 2010 | GE GLD5800L Dishwasher
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Stove door will not open after cleaning
does the oven respond to any controls??? or is it dead??? if it responds, id try to restart a clean cycle, this will attempt to lock the door if it does, then in a few seconds cancel the cycle and the door should unlock. or you can can try to disconnect the power to the unit for a few min and upon restoring power the first thing most ranges do is to self check there latches.
Apr 03, 2008 | Kitchen Ranges
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Frigidaire GLTF2940ES Front Load Washer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
