Question about Panasonic PT-47WX42 47" Rear Projection Television
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more than half of the horizontal distance across the bottom. The picture has a "double vision" effect all around this area, as well as doubling along the top part as the screen as well. I tried to fix the convergence by manually adjusting the red/blue/green, but it doesn't work--The crosshairs are not straight at all, but rather skewed, and at angles so that the colored crosshairs can never disappear...The center crosshairs are relatively straight, its just the outer perimeter ones that are out of wack..the corners are the worst.
  • Panasonic Master
  • 5,138 Answers
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Posted on Sep 10, 2010
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red ,Blue and Yellow lines off,curving inword from top and bottom
Its failure of 2 convergence out ICs and requires replacement.
You can replace these ICs if you have basic electronics knowledge and good soldering experience. let me know to provide you more info about parts.
Feb 20, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
I have my panasonic tv
This is a convergence problem and is either bad connections at the convergence IC or defective ICs. If you can solder, try resoldering the pins on teh convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink and may be marked STKxxx.
Keep us posted on your progress.
Dan
Jun 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Power problem
would require some troubleshooting, common problems would be convergence amp ic and high volt transformer transistors
If you are really brave tackle this TV FAQ.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm
Dec 04, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
401 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
