Question about HP Compaq Presario SR2032X PC Desktop
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was working until last night. Nothing changed physically for this computer
  • iBar Sep 10, 2010
    Thanks for the response. The monitor is good. I connected it to another computer to check. I replaced the onboard video, still dont see anything on the monitor. The monitor does get the signal.. its just that there is no info. When I disconnect the video cable, the monitor shows the "no signal" message, when I connect, the message stops but there is no other output.
  • iBar Sep 10, 2010
    I did this too. As mentioned earlier, the keyboard blinks for a brief second and then no response. There are MoBo's avaialble for $70, but I am not sure whether the problem is with MoBo or PSU sending low power to MoBo. I guess its time to upgrade. :-(
    Thanks for your response. Much appreciated.
  • HP Master
  • 11,800 Answers
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Posted on Sep 10, 2010
  • 1 more comment
  • iBar Sep 10, 2010
  • Azrael SRL Sep 10, 2010
    Last attempt - try to enter the BIOS by pressing F1 during boot. If even this fails then your motherboard is dead. Replace it.
  • UpInBuffalo Oct 25, 2010
    I had same problem... replaced memory, motherboard, cpu, cpu fan, cmos battery, power supply and every now and then it boots up... like I said... only every now and then, mostly not at all... everything acts like it's working but cpu is cold. even went as far as replacing the case. it's the craziest thing I've seen in over 25 yrs of working on pc's. At first when I had the motherboard in I had it standing upright in the case... it worked... when I put in in place it wouldn't work. I put insulators inbetween case and motherboard... still wouldn't work. Since I've basically completely rebuilt it I don't know what else to do...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
HP P4SD, its running good with 4 gb RAM, P4 3.0ghz, and a couple sata hd. The problem is the fan output voltage, i havent been able to read the output chassis and cpu cooler pins voltage cause i can find...
"i can find my dmm?" did you mean CAN'T?
"its clearly off", what is off?
the fans are 3 pins,2 are power, one is RPM tachometer.
"it all works fine", so you can boot and run any OS, ?
"the voltage reads +12vdc", where, at fan or PSU?
the fans run off 12vdc, they are DC motors (from outside fan)
if the fan runs slow at 12vdc the the fan is bad or is a low RPM
fan, as some are, bigger fans run slow, for less noise.!
first is the CPU fan it must run full speed, if not the CPU will overheat in seconds and ALL CPU shut them selves (by there selves) this way. so CPU fan is first. what does it do... there....?
then BIOS screens. GOT BIOS UP? and running? with, ESC key pressed>.
let me guess your symptoms
1: PC dead. will not boot.
2: BIOS dead.
3: all fans DEAD,.
4: power switch works and all PSU voltages read right, (seems not)/?
5: if the PSU power wire reads right(DMM), matching the side sticker voltages, and the CPU is dead, the MOBO is dead, or CPU is toasted.
here is a modern PSU, sticker.
see 5 to 10 power lines, see them. all must read correctly
if a fan is dead, then its dead if 12vdc is present on the fan power pins.
Apr 28, 2017 | HP Asus Motherboard P4SD-LA Socket 478...
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Compaq presario doesnt boot upon powering up
boot into the bios or if bios support diagnostics boot into that (typically F1 of F10 on power up) If that is not an option boot off the CD recovery disk and run diagnostics on the HD. Let me know we can take it from there.
Jan 30, 2010 | HP Compaq Presario SR1830NX PC Desktop
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
No booting for compac presario
do you hear your power on self test beep? check your video card. the monitor has a light on it it should be green if its working. what color is it? check all of your video plugins. It sounds like its booting but without video who knows
Jan 02, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario SR2032X PC Desktop Logo
355 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
