Question about Jabra Stone Bluetooth Headset
Won't turn on even after being charged - Jabra Stone Bluetooth Headset
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Asus tablet
buy a new phone
May 19, 2013 | Cell Phones
My brand new Wolvol Android won't even turn on
I recommend you contacting the seller. They seem to have prompt service.
Dec 24, 2012 | Coco Android 2.1 Tablet (837121001186)
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
My truck won't even turn over. I can jump it and it runs but when shut off it won't startagain
if it turns off as soon as you take of the jumper cables the problem is the charging system. it could be the alternator or relay or a fuse. and after that you need to charge the battery.
Aug 05, 2012 | 2005 Nissan Frontier
Even with battery charged, sometimes the machine won't turn on when unplugged
It sounds as though you have a defective battery. You will have to go through Macintosh for assistance.
Apr 27, 2012 | Computers & Internet
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Jabra Stone Bluetooth Headset Logo
402 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
