Question about TOA Electronics Audio Players & Recorders
Toa integrated amplifier model BG-1120 will not stay powered on. When power it turned on the unit circuit breaker trips.
  • 44 Answers
SOURCE: Denon Power AMPLIFIER
Try these links
http://ca.denon.com/ServiceCenterLocator.asp
http://www.fredsoundofmusic.com/denon_audio.html
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
  • 104 Answers
SOURCE: There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Posted on Nov 04, 2008
  • 81 Answers
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
SOURCE: Carrier air conditioner
i have nothing on my thermostat. I was going to install a programable thermostat so I disconnect my old one. When I couldn't use the new one I reinstalled the old one and now it's like there is no power to it. Checked circuit breakers and found none tripped and tried thermostat in upstairs since I have two thermostats and it works fine there What next???
Posted on Jul 22, 2009
My toa a-912mk2 amp does not work and the red protect light stays on
• Check for shorted power transistors, and extract in pairs.
If it powers up, without protect..
• Check again for possible additional components before replacing
the bad ones.
A good amp never produce an over of 0.7V on its output.
Sep 06, 2012 | TOA Electronics A912MK2 Amplifier
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
I have a crown 802 amp,,, lastnight set up to play got everything going playing music threw it and then,,,,10 min later it sounded like someone pulled the power on there ,,went over to kick it back on and...
Hello
surely there is some short circuit inside you amp, which causes heavy current flow, when you switch On it now. The main cause of this type of fault is with shorted audio output section inside the printed circuit baord. will have any shorted Integrated circuit [IC] or power transistor or MOSFET.
Your amp need service. Never switch in ON, until the fault has been rectified, as it may cause more component to be get damged.
Get it serviced by any expereienced service technician, as this work is skilled one, must have thorough knoledge in electronics, all tools to do the work, ability to loacate the faulty component etc. If you have all these, inform me. I'm happy to assist you further. The more you need is patience and concentration. OK.
Feb 05, 2012 | Crown XLS 802 D Amplifier
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
Trips on power up
It has a short circuit on the final steps of the outputs, maybe the common called "final transistors or power amplification IC (integrated Circuits)"are blown. You don't have the ability to resolve this problem, so take the unit to a facility authorized repair.
Dec 29, 2009 | Behringer EUROPOWER EP2500 Amplifier
20amp breaker tripped unexpectly tonight. tried resetting at panel but won't click all the way over and little red indicator also on the breaker
Hello, In order to reset circuit breakers that have tripped under load, you must first flip the breaker all the way OFF, before you can then turn the breaker back ON. This should reset the breaker to turn the power back on to the circuit supplied by this breaker.
The red indicator is just there to make it easier to find the tripped breaker. Typically, the red indicator flag is a special feature of Square D QD breakers and panels.
If the breaker immediately trips again and doesn't stay on, then the device it is providing power to, still has a fault and it needs to be looked at to determine what is causing the fault and the tripping of the breaker.
Be sure to turn the breaker OFF if you are going to check the device for potential problems.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | General Electric 20amp 2-pole GFI circuit...
Every time i turn on power it snap the reset breaker. and won't power up.
unplug everything but the 12v power/remote power and ground. turn on and see if it triggers the safety. if it does you have a short in the amp. if it turns on and stays on, plug one cable in at a time to see whats making it trip.
Sep 24, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
80 watt impedance matching volume control
check your spekaer cabling first for any loose connection. if everything as usual then something is wrong with either your speaker system or the power output stage of your amp. you may call it a "circuit breaker" but it actually overload protection of the power amp so as not to damage speakers or amplifiers. have your speakers checked for burn coils. you can also try to remove or turn off speaker switch, turn on the power, level up the volume and see it the system still stays on and does not trip (as you called circuit breaker) if the unit remains on, then it must be your speakers. though it could also be a leakage in the power transistors of your output stage, it something a technical person have to do to check anyway.
redrivera
Mar 25, 2008 | Audio Players & Recorders
290 people viewed this question
Top TOA Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a TOA Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
