Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Our Amana has a reocurring defrost problem where the back of the freezer clogs with ice every three weeks. Is there anything we can do?
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 10, 2010
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
My Amana refrigerator defrost timer is supposed to cycle every eight hours. Instead it takes about 14 hours to cycle around back to the defrost mode. The defrost mode does last for the proper 20 minutes....
Relax, some people exagerate was all I was saying.
Anyhow, go to a good parts store and ask for a Supco EDT (Electronic Defrost Timer) replacement as they are more reliable and not much difference in price.
May 15, 2010 | Amana ABB1921DE Bottom Freezer...
Frost builds up in the back of the bottom freezer (Amana ARB224RCW refrigerator) We have defrosted it, but the frost builds back up in 2 weeks. We don't think the freezer is overloaded.
ITS NOT OVERLOADED. YOU HAVE A DEFROST PROBLEM. ONE OF THREE THINGS ARE NOT WORKING. TIMER, DEFROST THERMOSTAT, OR THE HEATER. THIS SHOULD BE CHECKED BY A QUALIFIED TECH. GOOD LUCK
Mar 16, 2010 | Amana ARB224RCW Bottom Freezer...
My amana side by side refrigerator is leaking on the freezer side ..puddle on floor or starts melting on its own
Defrost drain is clogged with ice and overflows from defrost. Lower section of freezer at the bottom area of the freezer back wall.
Jan 31, 2010 | Amana ARSE66MB Side by Side Refrigerator
The inside of the refrigerator get full of water condensation(lots)
It is not condensation
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Amana Refrigerators
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
133 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
