Question about Haier HSB03 Compact Refrigerator
Compressor starts to run and the compressor kicks off and then keeps trying to start and motor is hot when i touch it. it never gets cold at all. what can i do to fix this problem.
  • Haier Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Model# 253.61821014 compressor keeps kicking off
Feel the top of the compressor is it hot? Usually when a compressor will start and stop this is called short cycling and it is caused by a defective start relay, overload and capacitor. Sometimes it it cause by a defective fan which when this happens all parts including a new fan must be replaced
241941004 Start Relay
218909913 Run Capacitor and a
242018301 Condenser Fan Motor
APPLIANCE911
It is not stuck in defrost mode with those symptoms
Apr 30, 2016 | Kenmore Refrigerators
Freezer cold control won't turn
Is the compressor running? The noise you hear could be the clixon on turning on and off. If that is the case, it is sort of like a circuit breaker that turns off the juice to the motor when it is drawing too much current (when it is frozen). If not running and hot to the touch and you keep hearing the click go on and off then the compressor on unit has gone to compressor heaven. U might also check to see if the start relay/capacitor is any good - if defective it will prevent motor from starting and cooling the unit.
Dec 25, 2015 | Refrigerators
Amana srd23v fridge not getting cold, fan in back will not come on
Check power to the compressor start relay. If power there suspect compressor fault if compressor hot. If compressor cold, suspect start relay. If no power to relay, suspect control thermostat
May 17, 2012 | Amana Refrigerators
French 3 door LG refrig.. Not cooling but compressor acts like it wants to kick on. The other guy said it was something wrong with my defrost cycle/ The refrig is defrosted but when plugged back in it is...
You either have a defective start relay or a defective compressor.
If it is clicking every 45 seconds or so,you can try a new start relay.
Feel the compressor.
Is it hot to the touch?
Is the compressor fan motor running?
Apr 06, 2011 | LG Refrigerators
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Husky 13gal 1.7 HP compressor when comprssor kicks on automatically it makes loud sound and smoke and fluid spray come out. While operating with compressor plugged in and valve turned ON, once psi is used...
my gess is its the motor again,, you may be trying to run it using low volts to feed the motor witch over loads the capasitor starter this would keep the motor in its start up windings witch would get very hot very fast as there only there to kick start the motor over once running the main windings take over i think i would take this compresor back and try to change it for a new compresor as its clearly not up for the job
Feb 11, 2010 | Air Tools & Compressors
Everything works but no cold air. I blew radiator
Hi, the click you are hearing is the klixon external overload relay on the compressor. The compressor is trying to start but is to hot and locked up. You can take off the back panel and make sure the condenser fan motor is running. If not, that's what is causing the compressor to get hot and kick the start relay on and off. If the motor is bad you could save the unit your self. If it is running fine, carefully put your hand on the compressor top and it should be very hot.The relay is connected to the common terminal where the wires go in and drops out when it tries to start. So, if fan is ok, you will need to have a service tech change it out. To be honest here it would cost you around lets say $1,500 to do this. Depending on the age of this unit you may want to look into another unit. This is the problem, trust me. Hopefully its the condenser fan motor thats out causing extreamly high head pressures. If not, the compressor has failed. Sorry to have to give you this news. Keep me posted.
Sincerely,
Shastalaker7
Jan 26, 2010 | Refrigerators
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Jul 03, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Haier HSB03 Compact Refrigerator Logo
181 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
